Old 10-21-2015, 03:15 PM   #11
Send a message via Yahoo to Magee
What is "PUGa? I tried to Google and only got dogs!
Next year, I'm getting the PUGs which I've heard also help considerably.[/QUOTE]
Thanks!
Magee
Magee is offline   Reply With Quote
Old 10-21-2015, 03:16 PM   #12
Who Dares, Wins
doc73's Avatar
Pop up gizmos..
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 10-21-2015, 03:30 PM   #13
Flybob's Avatar
I had one in my small trailer in the past. They work, but they can remove a limited amount of moisture in a day. So in less you have an A liner or a small PUP you will not be happy. Currently use a 30 Pint standard one. Ran separate power and drain thru floor. I don't have to empty or leave TT plugged in. Works great.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-21-2015, 03:33 PM   #14
BamaBob's Avatar
Originally Posted by doc73 View Post
I just put a eva-dry self contained unit on our counter. It is a stand alone unit that is plugged in only to recharge the desiccant.
Have not used it yet, this weekend and following will be the maiden voyage to see if it cures our condensation issues as well.
They are *THE BOMB* no more nasty damp-rid for us. We have used them for a season now (here in the deep HUMID South) and they work very well. Better news: since they are working all the time they seem to improve on the efficienciy of our 2 AC. We have NO problems keeping the unit at 70 deg in 100 deg heat!
Originally Posted by aceinspp View Post
What was the cost and how big is it? Later RJD
You can get them from Amazon for @ $30 for a pair (and, yes, you want one fore and aft in your unit)
http://www.amazon.com/gp/offer-listi...&condition=new
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 10-21-2015, 03:41 PM   #15
jeff64's Avatar
Recently purchased the eva dry 2000. Bought towards end of AC season so can't give you much feedback. Used once with furnace on and I can see that it removed condensation that I normally experience. In that respect, I give it a plus. This one is good for 2200 cu ft space which is about what the TT is.
My primary reason for this was to improve the efficiency of the 13.5 K Btu AC in the TT. Wrong season to evaluate it's efficiency on this. Did run in TT at home and it pulled about 2C. of water out of the air. so, it does function. Reviews on it were pretty decent so I took the bait.
Weighs about 6 lbs. Size 14 x 9 x 6, makes very little noise and the reservoir holds 2L. Specs say it will pull 20 oz/day at 85 degrees and 86% humidity. @Amazon. For $80 if it improves the AC efficiency and allows it to cycle, I'm happy
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-21-2015, 04:12 PM   #16
Those with a dehumidfier, do you drain into kitchen sink or shower to grey water tank?
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 10-21-2015, 04:14 PM   #17
Who Dares, Wins
doc73's Avatar
Amazon.com: Buying Choices: Eva-dry E-333 Dehumidifier, Twin Pack
So it did help with the foggy windows in the morning? I saved the receipt for it and box... Figuring if it did not work... Back it would go..
2015 ChevyHD D-Max
Old 10-21-2015, 04:15 PM   #18
Who Dares, Wins
doc73's Avatar
Many of the smaller ones have a tank to hold the water... The karger ones seem to have the ability to also have a hose attached but they are the larger ones so it seems and might take up more space than we have in the trailers. Either one would work, depends on where you want the unit to sit. My sinks and shower all drain to one tank though..
2015 ChevyHD D-Max
Old 10-21-2015, 04:34 PM   #19
Flybob's Avatar
Those with a dehumidifier, do you drain into kitchen sink or shower to grey water tank?
I added a 3/8 clear hose thru the shower pedestal then thru the bottom of the trailer . Just inside the trailer I added a quick connect. Then a matching quick connect to a 3/8 hose to the dehumidifier. Works great and no worry about filling anything. I originally ran into the shower but there was some rust in the dehumidifier discharge and it would stain the shower floor. I can send pics if needed.
TST Tire Monitors
2 100W solar panels
Old 10-21-2015, 05:00 PM   #20
Georgia Frog Rally 2018
aceinspp's Avatar
29.99 at home depot. Size of a large coffee can.
Thanks for the info. Will check next time at HD but may be to late in the year now. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
