Old 08-26-2012, 03:58 PM   #1
timarti's Avatar
Smoke detector works!
Decided to try out the oven in the trailer. Manual said there might be a bit of smoking on first use. Turned it on to heat up and shortly thereafter came back to the smoke alarm blasting and the trailer full of blue smoke. Had to crack open the vent and the Fantastic fan. Had the AC going because it is way hot out and didn't want to turn on the oven in the house where the AC is only in the bedrooms. Took about a half hour to burn off whatever was in there.
On the plus side, I used the pizza stone trick I learned on this forum to even out the heat and got perfect lemon poppyseed streusel cake! Yum.
Tina & Ted & pooches
2012 Ford F-150 XLT 5.0L V8 4x4 with tow package
Andersen WD hitch with sway prevention
2012 Rockwood UltraLite 2304s trailer
timarti is offline   Reply With Quote
