Old 09-18-2012, 09:04 PM   #21
Originally Posted by Happytrails2U2 View Post
Mine doesn't have a tab or a screw at the top either. It looks like the handle would need to be pried off but I don't want to do that without knowing for sure how it comes off.
Post a picture of them. There has to be an insert in the top of the handle that is removable. They have to be able to assemble them and also replace the "O" rings.
Old 09-19-2012, 06:58 AM   #22
Lanningjw's Avatar
A couple of years ago I make the mistake of putting the canaster back in its hold with out drying the water off the threads and it cracked after a cold Minnesota winter.
Found out the hard way when we charged the water system in the spring and it was leaking...... Hair line cracks in the threads. cost me around $50 for a new one.
2012 Windjammer 3001W
2010 Roo 19 (traded in)Mustang pop up (Sold)
1,000/10,000 equalizer
2000 Lund fishing Boat/2005 King Ouad 700 ATV
Windjammer lives at a Resort in Northern Minnesota. Lots of walleyes!
Lanningjw is offline   Reply With Quote
Old 09-19-2012, 06:35 PM   #23
Arn
Arn
No idea how to post a picture but I finally took a good look & the whole top piece pries off to give access to the screw. Thanks for your help.
Arn
Arn is offline   Reply With Quote
Old 09-19-2012, 06:51 PM   #24
Good that you got the top off. Just pay attention to the orientation of the valve inside and put it back the same way. I didn't the first time and had to take the other one apart to see just how to do it. Learned a long time ago not to take two identical things apart at the same time. Leave one for a pattern.
Old 09-19-2012, 08:20 PM   #25
Arn
Arn
If your handle looks like this, pry off the top piece. You can see the lines in the picture, just be careful, it's cheap plastic. My next mod will be household faucets in bathroom & kitchen.
Arn
Old 09-20-2012, 06:22 AM   #26
Mine looks similar to that. I'll check it out this weekend and see if I can get it off without tearing it up.
Thanks.
Happytrails2U2 is offline   Reply With Quote
water filter, waterpur
