Old 04-30-2011, 11:08 PM   #1
Some issues with new 8312SS
Pic ked up the new unit a few weeks ago. Drove home 8 hours with off an on rain. Next day noticed the carpet was wet in front of the u-dinnette but it was not wet around the corner of dinette. FR said probably due to high winds I was driving in some rain got through the seal. Ok. Drove down to Myrtle Beach a week ago and it rained some. Same issue. Carpet was slightly damp. Issue was some gaps above the wheels and rain was splashing in the underside from the tires. Mobile Repair applied a lot of silicon to the gap and then siliconed the screws where the slide attached underneath. Hopefully fixed.
Next noticed a small amount of water on the fender lip between the passenger tires. Area is directly behind shower. A flagstaff owner with the same model came over and pointed out his was wet and we checked mine and sure enough so was mine. It appears water may be getting between the tub surrond walls and the tub. Wife said the water smelled soapy. Will silcone around the whole tub where the tub surround wall meets the tub and hopefully this will fix it.
Noticed the TV that is mounted in the bedroom was hard to see as it did not have much angle and certain shows part of the screen was almost blacked out. Wound up installing longer plastic sleeves to angle the TV more at the top and this made a big difference.
Outside kitchen cabinet doors rubbed and had to adjust one door so that they both close without hitting.
Outside of this we love the unit. Anyone else experience any of the above?
cecilt is offline   Reply With Quote
Old 05-01-2011, 06:29 AM   #2
Herk7769's Avatar
My only water leak (so far) was the AC foam seal between the roof and unit was improperly installed and began to leak after it had been on the road a while.
The Flourescent lit LCD TV's have a very limited viewing angle and are probably a bad choice for campers (folks laying on the floor can't see it at all; in my layout I have a choice to angle the L/R TV at the dinette or the couch to be watchable), but we are stuck with them.
Plasma TVs have better viewing angles than LCDs but draw three times the power.
The new LED lit LCDs are not much better; but some.
Forget 3D anytime soon (the active glasses type has an even tighter viewing angle), but there is a new type that uses the same "cheap" passive glasses used in theaters that is much better. I was reading about them from Crutchfield.
HAM CALLSIGN - KC3FFW
Old 05-04-2011, 10:16 PM   #3
FarmerMT's Avatar
Wow, I am very disappointed to see issues like this on a new trailer. Looks like some better quality control is needed at the factory. I hope everything works out.
Phil, Michelle, Logan and Wyatt
2006 Dodge 2500 Heavy Duty 5.7 Hemi
2012 Rockwood 8312ss
FarmerMT is offline   Reply With Quote
Old 05-22-2011, 07:15 AM   #4
Just purchased the 2012 and didn't notice any problems like the ones mentioned. However, didn't specifically look. It was raining when we returned home. I will be paying particular attention the next time we travel in the rain. I just got rid of one competing brand that we fought for five years of delaminaton and water issues. I can't do it again.
mblanks2 is offline   Reply With Quote
Old 05-27-2011, 11:10 PM   #5
FarmerMT's Avatar
I just towed my new 2012 home from the dealer. 200 miles of Rain/Snow/Hail. 40mph head wind with 60 mph gusts. It was just about the worst conditions you could imagine. I had no leaks, the only issues I had was the fridge in the outside kitchen rubbed up on the cabinet. It seems to be bolted in so the factory just set it to close, you can barely see the damage. The Factory also forgot the heated mattress (dealer reimbursed) and the extra roof fan. The dealer installed one for me. I am so glad I have the Equalizer hitch. The trailer tracked nice behind the truck. The Hemi got 6 mpg up the steep pass out of Helena, Montana and then averaged about 9 the rest of the trip. I had some tranny shift issues that I will reprogram tomorrow and hopefully solve. We are very excited and can't wait to load everything tomorrow!
Old 05-28-2011, 07:33 AM   #6
jimh's Avatar
now u know why the tv's are placed at eye level at the store.
for my home, i purchased a plasma because of the viewing angle.
recently bought a larger (24" i think) for the trailer bed room. got the best i could get for the vertical viewing angle but still wound up making an angled shelf to place it on. (i would get on the floor and check for best picture. then i would look at the manufactures posted specs).
leaks, so far just from broken faucets and bad or no seal around the shower faucet.
jimh is offline   Reply With Quote
Old 05-28-2011, 09:54 PM   #7
Hi,
I need some help we got our new 26 FBSS and the drains on the kitchen sink seem to be installed in upside down the black rubber grommet is showing and I can't get the sink drains out is my thinking right?
Al
ALMcKinney is offline   Reply With Quote
Old 06-04-2011, 12:41 PM   #8
FarmerMT's Avatar
Al,
Can you take a picture and post it? Sink hardware is real easy to fix.
Old 08-01-2011, 07:31 PM   #9
We picked up our new 2012 8312 SS at the end of April. We love the layout of the trailer but have had quiet a few issues.
Our biggest issue was finding out the outside kitchen sink drains to the black tank. No one from the dealer or the manufacturer told us this and we only learned when we had a back up of the black tank and it leaked out through the sink. Besides a huge mess of waste, it damaged our outside stove and leaked into the back bunk room ruining the cushions to the bottom bunk couch.
When we picked it up and drove home about 140 miles we found a huge bubble in the sidewall of the tire and that needed to be replaced.
We also had an issue with the hot water heater not igniting and building up gas. When it would finally light it would through flames out of the door.
One of our cabinets is coming unglued at the joint.
It's at the dealer now being worked on. Hope this resolves all of our problems. Our last trailer was 7 years old when we traded it in and we didn't have this many issues with it the entire time we owned it. This is our first Rockwood and I hope we didn't make a mistake.
djwaltz is offline   Reply With Quote
Old 08-01-2011, 10:15 PM   #10
FarmerMT's Avatar
I have also had some issue's. I chalk up most of the problems to the speed in which the units were produced to meet customer demand. Now I know Forest River brags about their quality assurance facility but think about it! I have been lucky so far as all of the issues have been very easy to fix on my own. My two newest problems are cosmetic, the Rockwood decal on the front cap is flaking off. I have put in a call to my dealer to get a new decal sent up to me. I am also having an issue with the trim piece along the bottom of the trailer. It is made out of some of the worst material in the world. It seems like it is plastic covering thin tin or aluminum. We do a lot of camping on gravel roads and we are getting dents in the trim. You cannot pound or pop them out. Overall I am happy with the trailer, but could see how others may be more upset with their experience. We have had many weekend trips, we are about to embark on our annual two week trip on the Oregon Coast. I am crossing my fingers that all of the kinks are worked out!
8312ss
