Old 07-09-2016, 07:08 AM   #1
Space about Fridge in 2502ks?
I just picked up my new 2502ks yesterday. I have a lot to do to get acquainted with everything on her as this is my first TT. Overall, there seems to be a lot of storage available, but I see a large panel above my refrigerator/freezer that seems to be begging me to explore. Is there anything behind this panel? Or is it possible I can make this into an additional storage location? Also the IRV33 stereo is the dumbest system ever. For 2 cents, I'd replace it with a quality 7" touch screen car A/V system, but it's new and I'm gonna try the warranty service route because I can never get enough frustration.
2014 Ford F150 EGOBoost
2016 Rockwood 2502ks
jlmanatee is offline   Reply With Quote
Old 07-09-2016, 07:26 AM   #2
SeaDog's Avatar
Normally if you have an RV fridge installed that space above the fridge is not used because of the heat from the fridge. You didn't say what the problem with the IRV was it does take a learning curve to get it working right. It is not a blueray player only standard DVD
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-09-2016, 08:00 AM   #3
Oaklevel's Avatar
See if there is a roof vent above the frig..............
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 07-09-2016, 08:09 AM   #4
Zone 3 volume is not adjustable. When selected it blares at full volume. Our service guy says that's not right. But his boss says that's the way they're supposed to work (???) and if we get it replaced, the new one will work the same way. Goofy.
Old 07-09-2016, 08:12 AM   #5
53flattie's Avatar
The boss is wrong. We have the same irv33 unit and all three zones adjust with the volume knob. Your unit is definitely defective.
2015 Rockwood 2306
2015 Tundra CrewMax
53flattie is offline   Reply With Quote
Old 07-09-2016, 01:16 PM   #6
Burnking's Avatar
irv33 problem
Did you "select" Zone 3 or just turn it on. To select and control I believe you need to hold the button down until Zone 3 is highlighted on the screen. The you can select the input and control the volume.
Burnking is offline   Reply With Quote
Old 07-09-2016, 02:25 PM   #7
DouglasReid's Avatar
"The Boss" has been promoted beyond his level of compitence
OBVIOUSLY "The Boss" has NO idea what he is talking about. All three zones should have their volume regulated by the volume control. They all three will go up or down with your operation of the volume control. You cannot make zone C soft and zone A loud for example but all three should work.
Tell "The Boss" to get off his duff and get it operating as it should!
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 07-09-2016, 08:54 PM   #8
Space above fridge
Our trailer is a 23 ft. Love the trailer but storage was lacking. Like you wondered what was above fridge. We knocked the panel out and nothing there. The back of the fridge vented up the side of the trailer to an oblong large roof vent. We installed a false back about 14" or so back which left plenty of room for the fridge to draft straight up to the vent. Stained and varnished the inside to match our cabinets and found a nice basket for crackers and bread. Also made drawers for under the bed and dinette. Added a drawer in the kitchen, added a pantry and knocked out a blank in the bathroom and inserted a laundry hamper. I Love all my storage space now.
wildwoodtraveler is offline   Reply With Quote
Old 07-09-2016, 09:20 PM   #9
What holds the panel in? How difficult is it knock it out? Is it re-usable after it's been knocked out?
2011 Traverse LT, 3.6L, FWD
Old 07-09-2016, 09:34 PM   #10
It was just glued and stapled in. We used a putty knife tapping it into the edges and gently prying all around. Yes, we were able to reuse the panel. It is slightly smaller than the width of the opening so you would need to frame it in front and back (You could also get thin Luan for the backer.) One frame to attach to and the other as trim. The inside sides were unfinished so we just sanded and stained. Be careful of the nails you use. The paneling on the sides is very thin. We used wood glue and a nail gun.
fridge
