Originally Posted by missing_link
I just found out today my power stabilizers will lift the tongue off the ground easily!! The stab jack motor barely started to strain.
Now I know why I was out of level after stabilizing.
Too bad the power stab jacks don't do anything for side to side movement. I'm in the process of adding the steadyfast system but had to stop and order the longer bolts to get through the wood strips.
Linc
If they are LCI jacks and the legs are not reinforced, you are lucky you didn't bend at least one leg.
