Originally Posted by dogman
I am looking into buying the Steady Fast System for my new 8314SS. Of course I don't know if it really needs it or not because I haven't picked it up yet. Does anyone have one on there TT? Is it something that makes a big difference? All advice and input is appreciated.
Yes, you will need something to keep It from rockin. Bad engineering in my opinion. When you pick up your camper pay attention on how they are in stalled. Nothing was change with the way the are installed on the back, but they did make a change on the front after 2006. On mine the front jacks are mounted on the tongue of the camper, when they made the change they moved them off of the tongue and closer to the front door, Check out the small piece of angle Iron the used the center of the angle Iron is not supported It bends in the middle just like the rear dose, that's where the movement comes from and It doesnt matter how tight you make the jacks the angle Iron will keep bending upwards and you lift the fromt of the camper off of the tongue jack. It would be better it scissor jacks were used. I made a change on the rear of my camper to help eliminate the bending. I have an 8314ss as well.
