Old 04-01-2013, 05:49 PM   #1
mstell2's Avatar
Steps
I have a 2011 Rockwood 8281 SS and the steps are becoming very soft, when I looked at them on the frame it was cracking and it was only two bolts that mount and two screws that help hold it down is that right or should there be more mounting bolts?
mstell2 is offline   Reply With Quote
Old 04-01-2013, 05:51 PM   #2
TURBS's Avatar
I would think there should be 4 mounting bolts.
2 front 2 rear.
TURBS
Old 04-01-2013, 06:22 PM   #3
mstell2's Avatar
Is there a phone number for a rockwood rep that I could contact about this since it's out of warranty and this is the second time I've had issues with the steps?
Old 04-01-2013, 06:35 PM   #4
Dave_Monica's Avatar
The phone number off the brochure is 574 642 2640. The contact name I had from before for warranty is Doug Fought.
Dave
Old 04-01-2013, 06:46 PM   #5
mstell2's Avatar
Old 04-02-2013, 06:15 PM   #6
mstell2's Avatar
Called flexco, they are sending some new rails, but don't know if this will solve the problem.
Old 04-19-2013, 08:44 PM   #7
mstell2's Avatar
Got new rails, still have a problem, on the back of the steps there are just two self tapping screws to secure to frame. One hole is messed up from all the moving. Think I'm gonna weld a bar across the back and have more screws holding to the frame. Will have to pull off plastic under steps to make sure not putting holes where they don't belong.
Old 04-19-2013, 09:37 PM   #8
Don't remove plastic or weld,use threaded pop rivets where the holes are stripped out. Then you can use bolts to secure the steps. Youroo!!
Old 04-19-2013, 11:22 PM   #9
mstell2's Avatar
I'll have to give that a try.
Old 04-19-2013, 11:31 PM   #10
TURBS's Avatar
What's a threaded pop rivet?
Old 04-20-2013, 05:11 PM   #11
It might be a rivnut?
2013 Rockwood 8281SS
2006 GMC 1500HD 6.0L 4.10 GAS HOG!
Rochester, NY
rcnhoward is offline   Reply With Quote
Old 04-20-2013, 06:05 PM   #12
crunchman12001's Avatar
I am pretty sure youroo was referring to one of these threaded pop rivets?
2015 F-250 FX4
Old 04-20-2013, 06:13 PM   #13
Yes but 5/16 x 18 size for the steps. Thanks, Youroo!!
Old 04-20-2013, 06:47 PM   #14
5/16" gr 8 would be ok, but I'll bet the inserts are only gr 2 which is not strong enough for steps that are cantilevered out as far as they are.
My Flagstaff has (2) 3/8 bolts in front and nothing but 2 self tapping screws into the frame at the rear.
Old 04-20-2013, 07:07 PM   #15
The 5/16 pop rivet nuts are the replace/repair for the oversize holes from the self tap sheet metal screws,he can use any good grade 5/16 fastener he likes. The oversize holes he/I were talking about are the ones in the frame at the rear. Youroo!!
Old 04-20-2013, 07:09 PM   #16
mstell2's Avatar
Oldcoot, that is the same way my steps are, I have a rockwood, one of the self tappers is wolowed out and can't get any screw to stay. Was thinking of welding a bar or angle iron across the back and putting in more screws. Just need to see what is behind the plastic trim first so I don't screw into something I'm not supposed to.
Old 04-20-2013, 07:18 PM   #17
Will no doubt work there, but I would not attempt to use a gr 8 bolt in them as the bolts will strip the threads if they are torqued to gr 8 torque.
Old 04-20-2013, 10:04 PM   #18
Good grade fastener and Loctite,75% better than Factory sheet metal self tappers! Youroo!!
Old 04-20-2013, 10:14 PM   #19
I don't see where anyone suggested using a grade 8 bolt.
Obviously that would be overkill for such a mundane job.
The threaded inserts should work just fine with a regular bolt.
bakken is offline   Reply With Quote
Old 04-23-2013, 09:30 PM   #20
mstell2's Avatar
My bother in law is getting me the tool to do the threaded rivets. i took off the plastic to see what is back there so i could see where to add some extra support. Not much back there to screw to so I welded a piece of angle iron across the back, I'm going to add a few more screws to help with support.
