Old 04-01-2013, 05:49 PM   #1
mstell2's Avatar
Steps
I have a 2011 Rockwood 8281 SS and the steps are becoming very soft, when I looked at them on the frame it was cracking and it was only two bolts that mount and two screws that help hold it down is that right or should there be more mounting bolts?
mstell2 is offline   Reply With Quote
Old 04-01-2013, 05:51 PM   #2
TURBS's Avatar
I would think there should be 4 mounting bolts.
2 front 2 rear.
TURBS
Old 04-01-2013, 06:22 PM   #3
mstell2's Avatar
Is there a phone number for a rockwood rep that I could contact about this since it's out of warranty and this is the second time I've had issues with the steps?
Old 04-01-2013, 06:35 PM   #4
Dave_Monica's Avatar
The phone number off the brochure is 574 642 2640. The contact name I had from before for warranty is Doug Fought.
Dave
Old 04-01-2013, 06:46 PM   #5
mstell2's Avatar
Old 04-02-2013, 06:15 PM   #6
mstell2's Avatar
Called flexco, they are sending some new rails, but don't know if this will solve the problem.
Old 04-19-2013, 08:44 PM   #7
mstell2's Avatar
Got new rails, still have a problem, on the back of the steps there are just two self tapping screws to secure to frame. One hole is messed up from all the moving. Think I'm gonna weld a bar across the back and have more screws holding to the frame. Will have to pull off plastic under steps to make sure not putting holes where they don't belong.
Old 04-19-2013, 09:37 PM   #8
Don't remove plastic or weld,use threaded pop rivets where the holes are stripped out. Then you can use bolts to secure the steps. Youroo!!
Old 04-19-2013, 11:22 PM   #9
mstell2's Avatar
I'll have to give that a try.
Old 04-19-2013, 11:31 PM   #10
TURBS's Avatar
What's a threaded pop rivet?
