Old 06-16-2019, 07:26 PM   #1
Suburban SW6DEL Deration
This weekend I was at about 9500 ft in CO and had issues with my HW igniting and staying lit. The Suburban manual indicates deration is needed as theyíre set for 4500. Canít find anything online but... go to a dealer or gas dude for an orifice change out. Weíre often at 8000 ft or so without issue. Question: it seems to work fine with the door open ( to the heater not the trailer , and I see some have used this as a solution. Is it OK to just run it with the open hatch in these situations??
Scottnweeze is offline   Reply With Quote
Old 06-18-2019, 08:38 AM   #2
SeaDog's Avatar
Having the door open to the WH compartment may help it run however it also can subject the unit to gusts of air that can blow out the flame. At that altitude you have a very rich mixture which can cause soot buildup in the burner tube and chimney once you are back to lower altitudes I would clean them to ensure proper operation.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-18-2019, 09:05 AM   #3
Thanks SeaDog. I bet I could rig up something to just open it up an inch or two at the top. I will add cleaning to my post trip to-do's.
2019 Geo Pro 19FD
2019 Toyota Tundra
2018 Male Newfoundland
"No such thing as bad weather, just bad clothing..."
suburban
