11-13-2017, 01:32 PM
Suburban water heater
Hello, my Suburban water heart is not producing enough hot water on propane, DW is always complaining when taking a shower. How can I adjust the temperature to have longer cycles of heating.
Thank you in advance for your help!!!
11-13-2017, 01:37 PM
I am not sure you can adjust the water temp.
I would check the valves on your water heater pipes. Many have bypass valves to aid in winterizing the heater. Yours might be sending both hot and cold to the shower and not just hot. SO your wife is never able to just pull full hot.
I made this mistake last summer. Drove me nuts until I figure out that I never changed over the valves after winterizing it.
Good luck.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Does it produce adequate hot water on electric?
11-13-2017, 01:45 PM
Kanadian Kamper
Has this ever been an issue before?
Is this a new to you rig?
Do you have both electric and propane heating options?
Lots of questions here.
We’re here to help if you can give us more info.
Ken and Terry
11-13-2017, 01:58 PM
2011 Flagstaff 831 RLBSS
11-13-2017, 02:11 PM
As we are five, our previous TT would run out of hot water in the middle of the 4th person taking shower IF I left only the gas or only the electric heater on.
The solution was to turn on both while the troops where taking shower...
After that and during the day I leave only the electric on....
That solved our problem.
2018 F150 XLT V8 HDPP
2018 Rockwood 2909WS
" Life is simpler when you plow around the stump..."
11-13-2017, 02:43 PM
In addition to the bypass valves, check the outside shower.
11-14-2017, 07:33 PM
Thank you guys for your help, found an empty tank of propane.. it will never work that way!!..happy camping!!!
11-14-2017, 07:35 PM
Thanks for coming back with an update.
11-14-2017, 08:04 PM
How can a 6 or maybe 10 gallons of hot water ever be adequate if DW stands under the shower for 30 minutes? She needs to learn to get in shower and get out. With my 10 gallon tank both DW and I can shower shortly after doing a load of laundry.
11-14-2017, 08:21 PM
Kasual Kamper
Originally Posted by donniedu
How can a 6 or maybe 10 gallons of hot water ever be adequate if DW stands under the shower for 30 minutes? She needs to learn to get in shower and get out..
No problem... Install one of these.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
11-15-2017, 12:08 AM
See Post #7 here:
http://www.forestriverforums.com/for...re-110160.html
Note that MOST people want to drop the temperature, because it's too hot at the kitchen and bathroom faucets.
2011 Traverse LT, 3.6L, FWD
