Old 04-23-2016, 07:52 PM   #1
Suburban Water Heater Problem
Just bought a used 8327SS this winter. Finally got it set up in our driveway. Everything seems to be working well with the exception on the water heater. I put the plug back in it after being winterized. When I turn the switch on from the inside it lights but will not stay lit. I have hit the right reset button a couple time in the unit (see picture). It will not stay lit for more than a couple minutes. Any suggestions? I do not know how it was winterized since I bought it used that way. Am I missing something?Click image for larger version
Name:	ImageUploadedByForest River Forums1461459111.503842.jpg
ID:	105878Click image for larger version
Name:	ImageUploadedByForest River Forums1461459136.955823.jpg
2008 Duramax K2500 Suburban
Allison 6SP - DSP5 Tuned
2014 Rockwood 8327SS
2012 Grey Wolf 28BH
2008 2500 Duramax Suburban
arich4387 is offline   Reply With Quote
Old 04-23-2016, 07:59 PM   #2
I am no expert by any means, but did you bleed the air out first and make sure it is full of water? Mine is gas/electric and so far I have only used the electric side. Did you bleed the air out of the propane lines? Jay
Jay2504 is offline   Reply With Quote
Old 04-23-2016, 08:04 PM   #3
crunchman12001's Avatar
Start with using compressed air on the copper tube to eliminate spiders, mud daubers and stink bugs living in there.
2015 F-250 FX4
Old 04-23-2016, 08:08 PM   #4
Broadway Joe's Avatar
Check your bypass at the back of the heater, if left in bypass mode there is no water in the heater.
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 04-23-2016, 08:09 PM   #5
Flybob's Avatar
Check the back side of the WH ( from a panel inside the TT). There should be 3 shut off valves they may be shut off ( keeping water out of the WH) See pic below. This is the winterized setting. To put back into operation, turn each of the three valves 90 degrees. If the gas has been off for a while, air in the lines may have to be bled out before the WH will light and stay light. Try running the stove for a while to clear lines.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-23-2016, 08:11 PM   #6
BooBoo23's Avatar
And if there was no water in the tank and you hit the electric switch you will now get to purchase a new heating element also.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 04-23-2016, 09:28 PM   #7
Ok figured it out. The water was bypassed so there was no water in the tank. Turned the valves to close the bypass and turned on the cold water into the water heater and the hot water out.
Thanks Jay2504 you got me thinking about bleeding it and I pulled the drain plug and realized there was no water.
2012 Grey Wolf 28BH
Old 04-23-2016, 09:32 PM   #8
On a side note how do I know if this is a gas/electric combo unit?
2012 Grey Wolf 28BH
Old 04-23-2016, 09:44 PM   #9
BooBoo23's Avatar
If you have the option for electric you should be able to see a small black toggle switch in behind the gas solenoid valve on the outside in the lower left corner. You may have to bend over to be able to see it. I'm sure someone will post a photo of it.
Old 04-23-2016, 09:48 PM   #10
wmtire's Avatar
This FAQ should fix you up:
Suburban's electric switch and much more
It does appear you have an electric heating element, as I can see the cover for it in the very first pic you posted.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
heater, suburban, water, water heater
