Old 07-22-2018, 12:13 PM   #1
GOODBYE SUIT - HELLO RV!!
Supplement to onboard Tank Rinser?
Hadn't considered it before, but I came across an article about using a supplemental tank rinser at the dump station. The article talks about normal dump process using the on-board tank rinser, then adding an external tank rinsing device afterward for assurances, including using the gate valve on the accessory to fill your tanks from the outside (both gates open) and running the exterior flusher to flush both tanks (again) at the same time.
Anyone do this??
HAPPIEST WHEN CAMPING!
2019 Rockwood 2104s ****
2017 Starcraft Satellite 16KS
2012 Jayco X23B Hybrid
2009 R-Vision C243S Hybrid
2006 Coleman Bayside PUP
HappyCamper1962 is offline   Reply With Quote
Old 07-22-2018, 03:56 PM   #2
I use a Flush King. It removes a lot of waste from the tank even after the factory sprayer is run for a while.
I don't think the factory tank sprayer in our Windjammer is as effective as the Torpedo spinning tank sprayer that I installed in our prior trailer. I don't know what the factory sprayer is, but it doesn't seem to work all that well. The Flush King seems to do a good job getting most the waste out of the tank.
2017 Rockwood Windjammer 3006WK
dankirk is offline   Reply With Quote
Old 07-22-2018, 05:58 PM   #3
jeff64's Avatar
X2 on the Flush King. Used many years with good results
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-22-2018, 06:09 PM   #4
NMWildcat's Avatar
X3 on Flush King. If you don't have one, get one!
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 07-23-2018, 12:25 PM   #5
OscarsMom2's Avatar
I would never have both the black and gray water tank valves open at the same time. There is too great a chance for cross contamination from the black to the gray tank.
We had a problem with our black tank having too much paper and not enough water. The flusher didn't seem to work, but dumping 3 or 4 buckets of water down the toilet did the trick.
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
OscarsMom2 is offline   Reply With Quote
Old 07-23-2018, 12:42 PM   #6
OscarsMom2's Avatar
We have a flusher in the black water tank and use a clear adapter before the drain hose. After reading the information about the Flush King, I am wondering what is the advantage is to using it compared to just closing the black valve and allowing the black tank flusher to fill the tank part way and draining?
Old 07-23-2018, 12:52 PM   #7
Prime Member
I empty the black, put a hose down the toilet fill it up with water and empty again. Repeat until flush water runs clear.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 07-23-2018, 01:10 PM   #8
We dump the black tank and then rinse with the onboard tank rinser that came with the RV. Every once in a while and at the end of the season I usually just stick a hose down the toilet and let everything clean out a bit more. There are several turns/angles to our black water dump line from the tank to the outlet. I am not sure an extra rinser put on the outlet with a hose attachment would do any good.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 07-23-2018, 01:14 PM   #9
SailorSam20500's Avatar
I regularly turn the water jet on my sewer solution to spray back into the tank. Doing so clears quite a bit of extra "stuff" out of the tank. Every so often I will go back and forth between running the rinse and back spraying to really get things cleaned up.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is online now   Reply With Quote
Old 07-23-2018, 01:20 PM   #10
Kaadk's Avatar
I see no benefit to using a sewer outlet connected rinser over the onboard rinser. In both cases, I would have to close a valve to let the tank backfill before dumping again to really do anything.
However, last year I picked up a toilet wand to use for our end of season dumping/flushing, and it seemed to do a pretty good job. I don't use it all the time, but now I'll break it out every few trips to really give it a good clean out, especially if I notice any odours or the tank sensors still registering something.
tank
