Old 06-13-2016, 05:32 PM   #1
Richbald's Avatar
Support by stabilizer jack or tongue jack?
Question: Our TT uses scissor jacks for stabilizing and I always leave the tongue jack down and supporting the front of the TT. Is there any problem with raising the tongue jack and allowing the TT to be supported only by the stabilizing jacks?
Rockwood Signature 8311SS Travel Trailer towed by Ford F-150 EcoBoost 3.5L
2015 Rockwood 8310SS Travel Trailer towed by a 2015 Ford F-150 with Max towing package
Richbald is offline   Reply With Quote
Old 06-13-2016, 05:34 PM   #2
Platokidd's Avatar
I would not do it! Leave the tongue jack down..Just my $5
Why would you want to do that anyway?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 06-13-2016, 05:37 PM   #3
Stabilizers won't hold that kinda weight. So yes leave the tongue jack down and use it to level/support your RV.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 06-13-2016, 06:39 PM   #4
Richbald's Avatar
Thanks gents for your replies. My reason is to do so for temporary adjustments to the tongue jack. In one case the TT shifted and the jack was leaning enough for me to be concerned. This might be OK in an emergency, however if I want to change the footing or some less urgent reason I began thinking that I would like some input from my FROG friends.
Old 06-13-2016, 07:01 PM   #5
Leathergypsy's Avatar
I would just leave the camper hooked up to the truck and THEN work on the tongue jack. Just my opinion.....
John N.
Madison Heights, Mi.
2009 Salem LE 27RBEC
2013 F250 Lariat 6.2L
Leathergypsy is offline   Reply With Quote
Old 06-13-2016, 07:26 PM   #6
Just set the tongue on a jack stand or blocks.
Old 06-13-2016, 11:32 PM   #7
Richbald's Avatar
Thanks everyone. Good advice
Old 06-14-2016, 04:56 PM   #8
DKRITTER's Avatar
It might be more important to look into how to keep the trailer from moving when not attached.
2015 Ford F350 CC SRW LB 4X4
2016 Cedar Creek 36CKTS (My Last FR Product)
20,000 LB Reese GooseBox Hitch
DKRITTER is online now   Reply With Quote
Old 06-14-2016, 05:28 PM   #9
There's no problem supporting the trailer with those stabilizing jacks. They are usually designed to support at least five thousand pounds each. I have used them to support the trailer while working on the tongue jack several times.
2015 GMC Sierra 1500
2013 Heartland North Trail 28BRS
spudston is offline   Reply With Quote
Old 06-14-2016, 05:46 PM   #10
Usually Confused Member
emm-dee's Avatar
Mine (6 of them) are rated at 7,000 pounds each. As was pointed out to me recently they are scissor jacks, not stabilizers. Never used them to support the entire weight of the trailer but set them pretty tight after leveling the trailer. The make the trailer rock solid when down.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
