Old 05-26-2018, 11:01 AM   #1
tailgate hitting power lift
When hooked up to travel trailer, and opening tailgate it rests on the switches of the power lift.
needs about 1/2 inch to clear.
Is there a shield to put on tailgate or power lift ?
ruggets is offline   Reply With Quote
Old 05-26-2018, 11:35 AM   #2
Some people have rotated the jack 90 degrees. Requires you to tap some new holes.
LCI smart jack head rotation
2011 Traverse LT, 3.6L, FWD
Old 05-26-2018, 10:36 PM   #3
Old Forester's Avatar
If I REALLY raise the tongue on our Windjammer 3029w, my Silverado tailgate clears the electric jack housing just fine. I have to do this to remove the WDH bars anyway to "unload" the 10K bars. It's also a nice time to drop the tailgate and remove whatever needs to come out from under the A.R.E fiberglass tonneau cover that can't make it over the side when fully open. Maybe your tailgate will clear your's too....
Old Forester is online now   Reply With Quote
Old 05-30-2018, 12:41 AM   #4
I would recommend a longer shank for your WD hitch. I ran into this with a Ford F-150 tailgate.
jsh58 is offline   Reply With Quote
Old 05-30-2018, 06:57 AM   #5
I just rotated the head 180* works great and no holes need to be retapped
cmysstailights is online now   Reply With Quote
Old 05-30-2018, 07:06 AM   #6
Just drill a New 5/8 pin hole in your shank to achieve the needed space! Youroo!!
Old 05-30-2018, 07:24 AM   #7
nomad297's Avatar
What year and type of Silverado do you Have? What year is your 3029W? I have no problems with my 2015 3500 or my 2016 3500 and my 2016 3029W.
Bruce
Old 05-30-2018, 07:30 AM   #8
Bruce
But you may NOT have the Same Shank length! Youroo!!
Old 05-30-2018, 07:32 AM   #9
nomad297's Avatar
True, true!
Bruce
lift, power
