Old 05-16-2016, 08:10 AM   #1
redcloud1's Avatar
Tank heaters
Our trailer is equipped with tank heaters and were camping in Ohio right now in 34 degree temperature. At this temperature should I be running the tank heaters?
redcloud1 is offline   Reply With Quote
Old 05-16-2016, 08:20 AM   #2
They are "Auto" makes no difference,they will come into play when needed,as long as Switch is On! Youroo!!
youroo is online now   Reply With Quote
Old 05-16-2016, 08:24 AM   #3
SeaDog's Avatar
Myself it would have to be allot closer then 34* before I would turn the tank heaters on. Keep in mind you are getting heat from the floor to the tanks and surrounding area.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 05-16-2016, 08:37 AM   #4
fonzie's Avatar
X2
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 05-16-2016, 09:22 AM   #5
CANADA FROG RALLY 2017
B and B's Avatar
By showering or using the Kybo you add heat to the tanks. I would not work till it would get much colder, hoping not till next November.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
Old 05-16-2016, 09:29 AM   #6
B&B how would using a "Temporary constructed Lavatory" add anything to your Holding Tanks? Youroo!!
Old 08-30-2016, 09:48 PM   #7
Time-Travelers's Avatar
Tank heaters
Has anyone installed the 'pipe'/'elbow' heater pads? Not sure what good the tank heater pads do if the pipes are exposed?
Linda & Paul
2014 Rockwood Signature Ultralight 8292WS
2016 Ford F-150 XLT 4X4 Supercab,
3.5L V-6 Ecoboost
Time-Travelers is offline   Reply With Quote
heater, tank
