Old 07-13-2011, 10:31 PM   #1
kdbware's Avatar
Question Tankless Water Heaters
I have a Rockwood 2011 2902SS with 6gal water heater and 30amp service. I figured a camper with a shower & bathtub would have the capacity to furnish enough hot water for at least one [short] shower or [small] bath for the kids - wrong!
Needless to say, I am considering upgrading to an LP tankless, but the only viable options are quite pricey (there's the RV500 for ~$1000 or Girard ~$700, each plus install) and am concerned with the power draw (would I need to shut off the A/C, TV, etc?) when in use.
I would GREATLY appreciate any feedback, especially if your using one of these units and/or if there are any other (preferable less expensive) options besides using a shower house or an outside shower.
Thanks in advance!
kdbware is offline   Reply With Quote
Old 07-13-2011, 11:47 PM   #2
for about $400.00 you can buy an Atwood 10 gal. gas/electric....4 exra gal. makes showers much better and most camper have enough room to take the bigger water heater
Bill Crawford is offline   Reply With Quote
Old 07-14-2011, 09:51 AM   #3
Anacortesians
The problem with tankless heaters is that they need a lot of power if the flow rate is anywhere near enough. Domestic electric ones are 220V and draw a lot of current. They are usually installed at every location needing hot water. Since they're on-demand, they don't have any heat losses from stored water and are much lighter (not an issue in a stick house).
I don't think a domestic type electric tankless would work in an RV due to the power required, but a propane powered one might. Whether one heater could supply shower and sinks is another issue to be considered, as is whether the propane plumbing can handle the gas flow required.
Frank and Eileen
No longer RVers or FR owners
Old 07-14-2011, 09:59 AM   #4
Grumpy Old Member
ChrisZazzara's Avatar
Hiya,
Are you heating your water with propane or electric? I only ask because I take a pretty hefty shower and I have yet to run my hot water tank to cold while burning gas.
True, electric and 115 volts is pretty slow going. But on gas, these 6 gallon tanks heat very fast and efficiently.
Just a thought...
Chris Zazzara
2012 Windjammer 2008w
2010 Dodge RAM 1500
Reese Dual Cam WDH
ChrisZazzara is offline   Reply With Quote
Old 07-14-2011, 10:49 AM   #5
Got one on the house...
Uses BOTH electricity and propane. I think the electricity is 120VAC. Would require some hefty propane tanks...
CorpusBragg is offline   Reply With Quote
Old 07-14-2011, 12:04 PM   #6
DAISY BOYKIN's Avatar
Upgrade the----------
Upgrade the thermostats from 120 to 140, run both gas and ele when using the shower. But you can not run it full bore while kids play, they can learn the "NAVY" shower way too.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is online now   Reply With Quote
Old 07-18-2011, 12:08 PM   #7
trudinator's Avatar
My DH and I recently used our shower after an extremely hot day. Neither of us ran out of hot water, even though he took his shower right after mine. You just have to turn the water off and conserve with showering.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 07-27-2011, 01:45 PM   #8
lindy's Avatar
DW and I have both showered one after the other and not run out of water. Like TRUDINATOR said you have to conserve. Wet down and shut shower off, lather up, rinse of
wet hair shut shower off shampoo then rinse off. Keep shower shut off as much as possible, you cant take a shower like you were at home is the bis thing.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 07-27-2011, 06:43 PM   #9
tomjsas's Avatar
I've seen some of the newer units promoting tankless propane water heaters but haven't known anyone that has one to find out how well they work. I would be interested to know myself.
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 07-27-2011, 06:59 PM   #10
yvesm's Avatar
Thanks in advance!
Make sure your electric water heater is on, the switch is located outside behind the water heater door (dumb place). Its a small rocker switch. Just make sure its off when you have no water in the tank or you shut the water supply off. I added a remote switch inside the camper for the electric shut off. I did come across someone that had a tankless water heater and he did not like it. The problem was that if you ran just a trickle of water the tankless heater did not kick on. The unit ran on propane and you have to have a cold weather kit in freezing weather so the water heater wont freeze up.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
