Old 07-29-2011, 12:48 PM   #11
Old car's Avatar
I don't understand the awning thing. We looked and looked at various models and makes and found nothing consistent in how the awning was placed. We wanted both doors as well. When we went to order ours (ended up buying right off the lot) they had 4 3008's on the lot--all 2012 models. Two units had the front door covered, one had the rear door covered and the one we bought had both. But I noticed the same thing on a Jayco model we were considering.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 07-29-2011, 02:12 PM   #12
DAISY BOYKIN's Avatar
Scan for the tv stations.
Once you raise the antenna, turn on the booster (AMP), you will have to scan for the local TV stations, You will have to select in the set-up of the TV the on-air antenna unless the place you are parked has cable. then you will have to scan for cable channels. When using the cable set up, you may need to turn the amp off.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 07-29-2011, 02:23 PM   #13
sfrye5853's Avatar
Originally Posted by ken0042 View Post
Also, don't forget to use TV Fool to see where the signals are coming from where you are camping.
Link to TV Fool
If you are camping in the middle of nowhere, the easy way to find the coordinates is with Google Maps. Zoom in on your campground and the click on the "Link Button." (Shown with an arrow below.) You will see the coordinates where I was looking are 38.674789 and -94.428177. You will only need 38.67 and -94.42 for TV Fool; as that brings you within a mile.
This is awesome... Can't wait to use it on our next trip.
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 07-29-2011, 08:16 PM   #14
Old car's Avatar
Okay, now for the stupid question. I get TV reception at the house--all the Kansas City metro stations. We live about 30 miles of Kansas City. Have yet to get a TV signal while camping. I found the antenna boost after earlier thread posts made me aware of this and the green light is on. The wall plate has two identical connections like for coax cable. One is marked "TV" and the other "Sat/Aux". I would think there should be a cable running from one of these to the actual television set. There isn't. Shouldn't there be?
Randy and Patty
Old 07-29-2011, 08:50 PM   #15
Nigels's Avatar
No. These are for other things, not sure what though, perhaps some one else can advise. Your system is connected behind the paneling and from what you say it is working perfectly well. If you do not get a signal in some remote areas it is because there is no signal.
Nigel & Bev
Brit Driver & Canadian Naviguesser
2011 Rockwood Signature Ultra Lite 8280ws
2011 Dodge Ram 3500 4x4 Diesel
Nigels is offline   Reply With Quote
Old 07-29-2011, 09:30 PM   #16
ken0042's Avatar
Just to clarify, do you mean you get them inside your house? Or do you mean you can get them inside your trailer when the trailer is parked at the house?
If the latter- can you name a couple of the campgrounds you have visited? I'll try to look them up.
The "problem" with digital TV is it either works; or it doesn't. Unlike analog signals where you can pick up a snowy image from a distant station; digital is either all or nothing.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 07-29-2011, 09:58 PM   #17
Old car's Avatar
Get signal in the trailer while at home in the driveway and this is without the antenna being raised. As for a couple of the campgrounds: Knob Noster State Park (Knob Noster, MO) and Bull Run Bluff Campground (Camdenton, MO).
While in the driveway, I turned off the signal boost and lost the channels. Flipped it back on and the picture came back. Guess it's just the campgrounds because everywhere we have stayed in fairly heavily wooded.
Randy and Patty
Old 07-30-2011, 12:35 AM   #18
ken0042's Avatar
OK, I've got 2 screenshots below. The first is Knob Noster, and the second is Camdenton. It looks like you may be out of luck at Knob Noster. The only channels you may pick up are KMOS (Digital), and K11OJ (Analog.) I'm still not confident as the analog signal is pretty weak even though it is close enough. (Look at the NM (dB)- the higher the number the better.) And KMOS while strong is alomst 40 miles away; which means any kind of terrain in the way and you are in trouble.
Camdenton does look better. I would try KRBK (Channel 49) as it is close and the signal is strong. The 3 other channels in the green should also be OK; they are further away but quite strong.
I hope that helps you read what the results say. If nothing else- now you have a hobby to do while camping; trying to find the TV signals.
ID:	7119   Click image for larger version
Wolf Pup T16P owner
Old 07-30-2011, 08:01 AM   #19
Rugged Brown's Avatar
Why isn't the system configured to keep the booster switch on at all times, if it is required to get a signal.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 07-30-2011, 08:14 AM   #20
Old car's Avatar
Thanks Ken0042. We are going out next weekend so I will see what we can get. Going down to Indian Point campground on Table Rock Lake near Branson. I have bookmarked the TV Fool page so I can see what it shows and start tinkering from there. Haven't missed the TV while camping but we hope to get out a lot this fall once it cools off some and college football season is just around the corner.
Randy and Patty
