Old 07-30-2011, 08:16 AM   #21
Old car's Avatar
Rugged, that would make to much sense! I'm an idiot when it comes to anything electrical. I'm sure there's a reason. Earlier in this thread someone said you turn it off if you connect to satellite/cable.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 07-30-2011, 08:17 AM   #22
Wanna Be Camper
SaskCampers's Avatar
Originally Posted by Rugged Brown View Post
Why isn't the system configured to keep the booster switch on at all times, if it is required to get a signal.
The booster is 12v so it will be a drain on your battery if left on and second it acts as a coaxial switch to switch between antenna and cable input.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 07-30-2011, 10:27 AM   #23
The booster switch needs to be turned off when hooked to cable. Wayne
wayne anthony is offline   Reply With Quote
