Old 10-08-2012, 08:35 AM   #1
Lanningjw's Avatar
The water is must be frozen
Woke up Sunday morning in Northern Minnesota with temps in the low 20's, no Water was coming out of the faucets. Seems the low temps froze up the red handled spigot and hose leading into the windjammer.
I was able to melt the frozen water with a torch at the spigot. The pressure pushed the rest of the ice out of the hose after I unhooked it from the city water connection.
This is my favorite time of the year to camp. Any ideas on how I can keep this line from freezing up? I was thinking it needs an insulated hose or a blanket to keep it warm.
2012 Windjammer 3001W
2010 Roo 19 (traded in)Mustang pop up (Sold)
1,000/10,000 equalizer
2000 Lund fishing Boat/2005 King Ouad 700 ATV
Windjammer lives at a Resort in Northern Minnesota. Lots of walleyes!
Lanningjw is offline   Reply With Quote
Old 10-08-2012, 08:45 AM   #2
Oakman's Avatar
When temperatures are expected to go that low overnight, I always fill the fresh water holding tank and disconnect the water hose from the spigot and drain it. When the temperatures warm up the next morning I reconnect the water hose. I’m taking it for granted you have heated holding tanks.
Many of the campgrounds I’ve been to require you to disconnect the water hose during freezing temperatures.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
Old 10-08-2012, 12:21 PM   #3
Lanningjw's Avatar
Thats a GGGGGGGGGGGreat idea, never evan thought of doing that! Thanks
Old 10-08-2012, 12:38 PM   #4
You can also buy a heating cable and wrap it and the hose.
Shop EasyHeat 30' 211-Watt Pipe Heat Cable at Lowes.com
Old 10-08-2012, 01:11 PM   #5
timarti's Avatar
Or buy one of those 'spensive heated hoses! That red faucet looks like a no freeze faucet. If the hose is detached, the water will drain out down below the frost line. I have one of those ouside my horse barn. Even so, up north where we are I have the pipe wrapped with heat tape, as well as detaching the hose. Another trick, blow all the water out of the hose after detaching. Beware if itis a metal fitting! (remember sticking your tongue to a metal railing in winter? Well maybe not in some parts of the continent) Anyway, I have a small air pump used for inflating exercise balls. Goes in the end of the hose, pump a few time and no more water in the hose to freeze. But you have to be quick when it is 40 below!
Tina & Ted & pooches
2012 Ford F-150 XLT 5.0L V8 4x4 with tow package
Andersen WD hitch with sway prevention
2012 Rockwood UltraLite 2304s trailer
timarti is offline   Reply With Quote
Old 10-08-2012, 03:58 PM   #6
I too drain the water from our hose in freezing temps. Alot easier than trying to thaw out the hose.
windjammer
