Old 04-18-2013, 08:34 AM   #11
Wanna Be Camper
SaskCampers's Avatar
Originally Posted by Bobo 3008 View Post
We have had ours since last August. Great layout. No more having to move to let someone walk by, especially while preparing dinner.
Only negative is I had a Blue Ox Sway Pro WD hitch from my Sunline. It did not fit. Any WD hitch system that has top mounted tension cams (the lift mechanism to tighten the chains) will not work. The V nose extends over the frame area where they mount. You have to buy an Equalizer brand WD hitch. A good hitch system but an added $650.00 expense that was not expected. Unfortunately, the dealer that I purchased the camper from tried to send me down the road with the Blue Ox, with the chains hanging at a 45 degree angle, telling me it was ok. Another lesson learned. Needless to say, I bought the Equalizer somewhere else at $150.00 cheaper than my "discounted price" from the dealer.
We got the minimum carpet option. Easier to keep clean and looks really nice. FR does a great job with choice of standard products.
Bobo
Your dealer apparently had no idea how to setup a Blue Ox hitch as I have one and it works flawlessly. The chains drop straight down. I have had the old style snap up brackets that you use the bar on and now have the rotary latches and both have worked perfectly. Also the Blue Ox when it is dialed in is dream to pull with. Yes the original snap up brackets are a tight fit and you can get a few dents in the lower metal panels but the hitch sets up correctly and the new rotary latches are the slickest thing I have ever used.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-07-2013, 03:34 PM   #12
How do you find the gas mileage on the Ford Ecoboost?
fancynancy is offline   Reply With Quote
Old 09-08-2013, 07:17 PM   #13
Old car's Avatar
It's right at 10 MPG. I think if you pull with a gas engine that's about what you get. My previous Silverado was about the same. Better MPG when not towing and truck is just more responsive when I am pulling.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
