Old 05-22-2018, 02:31 PM   #1
Rookiewood's Avatar
Tilted slide outs wile opening. Design Flaw ?
My two slide outs tilt down wile opening.
Once they are open they become perfectly leveled.
I have no problems with the seals in the open or close position, everything seems to be working good and no leaks.
Is this normal?
My previous camper had it too, but this new one broke what they call ď slide out corner blocksĒ. I honestly think it is a corner block design flaw.
What say you ?
Anybody with a similar situation ?
2016 Chevrolet Silverado 2500HD LTZ Z92
Rookiewood is offline   Reply With Quote
Old 05-22-2018, 02:36 PM   #2
Tilt
My main hydraulic slide will do that, have had no issues.
Lifestylers is offline   Reply With Quote
Old 05-22-2018, 08:40 PM   #3
Normal
Mine do this.. no problem.
Mike
2016 PrimeTime Lacrosse 324RST
TV = 2017 Ram 3500 (aka FRAM)
walaby is offline   Reply With Quote
Old 05-22-2018, 09:52 PM   #4
Mine do this and it's just not right, is it? It's under warranty so, if it falls off I'm covered.
vmax is offline   Reply With Quote
Old 05-22-2018, 09:55 PM   #5
3 of my 5 do. the other 2 are the swintec style (forgive the spelling) never had an issues or problems been that way sense new.
Kimber45 is offline   Reply With Quote
Old 05-22-2018, 09:58 PM   #6
cavie's Avatar
Yes, when to top of the slide hits the wall of the trailer the bottom will continue out until it is level.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 05-22-2018, 10:02 PM   #7
Rookiewood's Avatar
The problem is not the slide tilting, it is the two per slide plastic corner blocks. When the slide tilts they brake. I would say every +/- 30 cycles !
Old 05-23-2018, 10:37 AM   #8
Rookiewood's Avatar
Just got a word from Forest River apparently they discontinued these parts and are going to replace them with metal ones probably aluminum ....
Old 05-23-2018, 03:45 PM   #9
It was one of the first things I noticed before ever buying. The dinette slide on the Sunseeker 2500TS would tip down when extending and coming level seating at the outward position. It only happened on one of the 3 slides. The dealer assured us that it was normal and it never caused us a problem.
PenJoe is offline   Reply With Quote
Old 05-23-2018, 05:03 PM   #10
I just make sure my 5th wheel is level before i bring them out.
Jdb95661 is offline   Reply With Quote
slide, slide out
