Old 09-20-2013, 05:49 PM   #1
Blucruz's Avatar
Tire Issue
Hello all,
I just bought a new 2013 8286WS back in July and have 3 trips on it totaling about 2500k miles. Yesterday we were heading home northbound on 680 in San Jose and blew a tire all to shreds. Before leaving the Flying Flags RV park in Buelton that morning I checked the pressure and all tires were between 47-50 PSI. (225-75R-15C 5ply).
After changing the tire I got looking at the writing on the sidewall and comparing to the Spec tag on the side of the trailer. My GVWR is 9480 while my tires rating at a Load range "C" is only 8600. I realize the tongue weight needs to be added in there as well, but as a former Truck Driver I could not believe that the stock tires were not rated to handle the entire weight of the vehicle.
A CHP happened to stop by while we changing the tire and he was even saying that load range "C" tires on this trailer was rediculous. I realize I have no recourse to go after the MFG because technically the tires are rated for the weight of this trailer when tongue weight is included but they are borderline at best. I would hope that in the future Forest River would spend the extra $6.00 per tire and put a load range "D" on there which is a 7 or 8 ply tire rated at 2500# each.
While I can't prove that weight was the issue that caused the tire to fail, it's going to cost me about $550 to replace all of them, small price to pay for safety but worth it.
I'm just curious if anyone else had had similar issues with their tires on a new Rockwood or any other FR trailer for that matter.
G
Blucruz is offline   Reply With Quote
Old 09-20-2013, 05:57 PM   #2
Windywest's Avatar
This forum is full of tire woes, and every manufacturer has their horror stories. It seems FR puts the cheapest tires they can on most units, just the allowable. I had a blowout on my last trip, LR C so replaced them all with LR E tires. I estimate that I didn't have 3000 miles on the tires, but what can you expect from Chinese junk. I replaced them with LR E Chinese junk, hopefully they will last a bit longer.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 09-22-2013, 04:54 AM   #3
salvi's Avatar
tire issue
When we bought our 8280W in the spring I noticed the C rated tires.
I had the dealer install E rated tires and have had no issues yet.
salvi is offline   Reply With Quote
Old 09-22-2013, 07:23 AM   #4
Witch Doctor's Avatar
We had Trail Express c rated. They were within the weight limit stated at the time it was weighted at the factory, as you load your unit it pushed to the limit. I got 6000 miles before I had a blow out and I know my pressure was at 50 lbs. When I called they said I had to send the blown tire to them for warranty. What a joke. I went and just changed them all to Marathons d rated. Lucky I didn't have any damage. Still fully loaded I'm not even close to what they are rated for weight. Still made in China being they are ST
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-22-2013, 07:38 AM   #5
acadianbob's Avatar
I agree with having as much reserve capacity in your tires as you can. It provides a safety margin IMO. Just make sure that your rims are rated for the additional pressure of a higher rated tire. My trailer came with C tires; I changed to Ds, but my rims were only rated for 60 pounds.
I might suggest a tire pressure monitoring system. It provides peace of mind and lets you know of an impending problem before it happens.
It is possible that your blowout(s) were due to heat caused by low pressure from a road hazard. Without a monitoring system, you do not know.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 09-22-2013, 09:27 AM   #6
Windywest's Avatar
After our blowout a few weeks ago, I bought the Tireminder TPMS, I haven't been too far with it yet, but so far it works great and I don't need to use the booster. They are pricey little units, but safety and peace of mind are worth it. As for the LR E tires I put on our unit, the actual tires (like all LR E) can be inflated to 80 PSI, the tire shop owner said with the amount of weight, I can just run them at 65 PSI, and as others smarter than me have said on this forum, it's the air that carries the load, not the tire. My rims are the HWT series 6, they are stamped on the back (dependant on bolt pattern ) 2150 lbs or 2830 lbs, so I can deduct that the rims will handle LR C, D, or E pressures. I winterized the unit this weekend, so next years first long trip will be the test.
Old 09-22-2013, 10:41 AM   #7
MarcusN's Avatar
We have a 2013 Rockwood 8289WS and had one tire this past week drop to 13 lbs, so I inflated to 48 psi and two days later it had dropped to 45.5 lbs. As I had read all the horror stories about exploding tires before buying I had planned on replacing next year (after 5000 miles) but with the pressure drop issue decided to pull the plug early as we have a 1000 mile round trip planned for October. My local tire dealer suggested that D LR would be ok but for $10 more per tire to go with LR E Carlisles. So with new tires and a large safety measure I feel more confident about a safe trip w/o tire issues. Dealer also gave me $10 trade in on each of the tires.
Mark & Barb
2013 8289WS Platinum Pkg
2008 F350 King Ranch CC 6.4
2013 nights camped 35
MarcusN is offline   Reply With Quote
Old 09-22-2013, 11:00 AM   #8
Windywest's Avatar
Just curious as to what pressure are you running with your new Carlisles ?
Old 09-22-2013, 11:52 AM   #9
Denver, CO
garbonz's Avatar
The TPMS is a great idea, but will not warn in advance for all situations, and may not warn in time to prevent damage. However, they still are a good idea IMO. They are primarily designed to provide warning of a puncture from a road hazard like a nail, where the pressure reduces gradually.
The way some of these tires are coming apart spontaneously, there have been reports here and elsewhere, that they shred apart and flap the side of the trailer BEFORE they lose pressure (or overheat) enough to alarm. They are no substitute for good tires running well within their load, pressure and temperature specs. If you are running China Bombs, then be extra vigilant and WELL below the max load.
I am running LR E tires on a trailer that came with them on 16in wheels right from the factory, although the trailer is Easily within LR D specs. BUT I have a TPMS and inspect them closely all the time. I will still change them out next year, when I can afford to.
2017 Fuse 23T
Old 09-22-2013, 12:30 PM   #10
MarcusN's Avatar
They are currently at 78 lbs from the tire mounting. I was planning on leaving them at that level for now.
Mark & Barb
tire
