Tire Pressures in Different Load Range Tires
I just bought an 08 Rockwood Ultra Lite 8283SS. Really nice unit and a great upgrade for me. The sidewalls on the tires on it were cracking so I decided to replace them on my own schedule rather than theirs. I've had enough problems with tires in the past to know that stronger is better so event though the specs on the Load Range C tires met the requirements for the trailer, I went with Load Range Es.
The sticker on the side of the RV says use 50psi which is maximum for the Load Range C tires. The Load Range E tires can take as much as 80psi. What is the correct tire pressure for me to use and the pros and cons of the higher pressures vs the lower.
THanks,
