Old 07-02-2019, 03:24 PM   #1
Tires
Have a Rockwood mini light 2504s
Have about 9400 miles on the castle rooks.
Don't want to press my luck, looking for suggestions from
Goodyear
Maxxis m8008
Carlisle
Tire size ST 205/75R. Load D 1054- 2054 max
Trailer is about 6500 loaded
grandpalee is offline   Reply With Quote
Old 07-02-2019, 03:50 PM   #2
ysidive
ysidive's Avatar
14 inch or 15....? If 14 I went to the 215/75R14 Goodyear endurance and have not looked back.… 215's load range D.... I think the 205's are only rated load range C, but I am not sure….Replace valve stems with metal valve stems...….
2018 Duramax 2500 LTZ
Freedom Express 281rlds
ysidive is offline   Reply With Quote
Old 07-03-2019, 07:00 AM   #3
Originally Posted by ysidive View Post
14 inch or 15....? If 14 I went to the 215/75R14 Goodyear endurance and have not looked back.Ö 215's load range D.... I think the 205's are only rated load range C, but I am not sureÖ.Replace valve stems with metal valve stems...Ö.
They are 14",. Thanks
Old 07-03-2019, 11:58 AM   #4
Lets go camping!
str8t six's Avatar
i have the Goodyears on my my 2504s. i think i went up to D rating on them.
i dont have any negatives to say about them. they seem to have made the trailer more stable towing as well.
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
str8t six is offline   Reply With Quote
Old 07-03-2019, 12:09 PM   #5
Many, many, many, many, many tire threads here.
The three most mentioned are Goodyear Endurance, Maxxis M8008 and Carlisle HD. (in no particular order) If you are able, it is always wise to go up a load range C to D or D to E.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 07-03-2019, 12:12 PM   #6
I am in the exact same situation as the OP. I have about 7k on my Castle Rocks, exact same trailer - 2504s.
I am planning to go with the Goodyear endurance tires in the stock size 205/75 R14. They are load rated D and cost about $100 each. My only hesitation is the rims. Those stock Lionshead rims are rated at 1900 pounds an the tire can go over 2000 lbs @ 65 psi. Not sure if it's worth just replacing rims while I do the job or whether the old rims will suffice.
Discount tire offers tire and rim combos that come pre-balanced, but not sure if they offer balancing on trailer tires. If you have to pay someone to mount and balance, then this may pay for itself and get you a more suitable rim for the tire's specification.
I didn't want to change ratios or size because the axles are pretty close together as it is. I don't want to risk any clearance issues. I am currently waiting for a warranty repair for a cracked fresh water tank, so have been on the fence with the tires. Let us know what you decide to go with. This is my next purchase.
DNA Dan is offline   Reply With Quote
tire, tires
