Old 03-10-2012, 07:48 AM   #1
MissouriCamper's Avatar
Tires
We bought our 2006 Rockwood 2603 in the Fall of 2005, and have probably put around 15 to 20,000 miles on it since purchase.
Was looking it over this morning getting ready to de-winterize it, checked my tires over and they still look good with plenty of tread. My question, it used to be a rule of thumb to get rid of tires after 5 years, irregardless. Does this still hold true for the tires manufactured in the past 10 years? Hate to expend money when not needed, but usually like to err on the side of safety. Would appreciate any opinions
Mike & Shirley
Millwright (Retired)/Homemaker
2009 F250 SD Super Cab
6.4L Diesel 3:55
2018 Flagstaff 25FKS
MissouriCamper is offline   Reply With Quote
Old 03-10-2012, 08:45 AM   #2
The newer tires are the worst. I have an old truck that has been sitting since the 1950's and the tires are still good. The way they make them now, 10 years would be a stretch.
But it all depends on where the camper sits most of the time. Ours is indoors in a heated/cooled shop when not gone camping, so I expect the tires to last a long time. But if the camper sits outside and the tires are exposed to the sun on a continuous basis, I would watch them carefully. If they showed any sign of deterioration, I would replace them.
Old 03-10-2012, 08:49 AM   #3
Oakman's Avatar
IMHO it's time to get new tires. If you don't replace them this year, I'd bet a dollar to a donut that this coming season you will have tire problems.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
Old 03-10-2012, 08:49 AM   #4
Triguy's Avatar
I understand this still to be true. That is, to replace 3-5 years whether they look worn or not.
The logic I have heard and read is that the rubber compounds in trailer tires contain more chemicals than car and truck tires to resist weather and ozone cracking and that these chemicals dissipate in 3-5 years.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-10-2012, 09:00 AM   #5
We had our last fifth for over 10 years and never changed the tires, and didn't have one problem. So to say that they should be changed after 5 years without knowing the circumstances is misleading.
The quality of tires is also important, as we don't run cheap tires. Our old fifth had Canadian-made Goodyears, and we switched the tires on this camper to Maxxis.
Old 03-10-2012, 09:03 AM   #6
Mountainmanbob's Avatar
after all of the reading
tire covers for around 30 bucks a pair
I think add some life
but
after all of the reading regarding most
factory equiped tires
(we) should not press our luck to far
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 03-10-2012, 09:08 AM   #7
Steeljag's Avatar
Eyeball them continuously, and let condition be your guide.
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is online now   Reply With Quote
Old 03-10-2012, 09:17 AM   #8
Oakman's Avatar
You can eyeball tires all you want but you can't see the condition of the tire within.
Bob and Joyce
ATU Local 788
Old 03-10-2012, 11:02 AM   #9
acadianbob's Avatar
I was in the same position. 5 year old Marathons (that have served me WELL) with about 20,000 miles. Some wear but visually perfect. We do lots of long trips; sometimes in high heat; as in thousands of miles; so I decided to replace them. I weighed the cost versus the consequences of trouble; possibly in the middle of nowhere; and went with new tires.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-10-2012, 11:12 AM   #10
" I weighed the cost versus the consequences of trouble; possibly in the middle of nowhere; and went with new tires."
That is definitely a major consideration.
Changing a tire on a busy interstate might even be worse than in the middle of nowhere!
