Closed Thread
Old 04-15-2014, 11:23 AM   #11
rburns4147's Avatar
Our Rockwood came with nitrogen filled tires also. I have my own air compressor at home and will be filling with air. As stated above, spend your money on a good tire pressure gauge and use air. If I take the 5er somewhere to have the tires topped off with nitrogen, I hear they charge around $5.00 per tire. I can't see paying $80.00 for the truck and trailer when I can do it for free myself.
Ron and Elizabeth
2014 Rockwood 8285-IKWS
2006 Ford F250 6.0 Diesel 4x4
rburns4147 is offline
Old 07-28-2014, 08:08 PM   #12
Costco will fill them if you need. Nitrogen Martians pressure much better with temperature changes and does not carry moisture like compressed air. My local ford dealer also used nitrogen and will fill the tires.
larryscsi is offline
Old 07-29-2014, 05:36 AM   #13
Incheon, S. Korea
BigBaron's Avatar
Marvin the nitrogen Martian doesn't handle pressure very well. Ask Bugs Bunny...
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline
Old 07-29-2014, 05:37 AM   #14
Incheon, S. Korea
BigBaron's Avatar
FYI - air is almost 80% nitrogen already.
BigBaron is offline
Old 07-30-2014, 07:43 AM   #15
PhoneDude 8289's Avatar
I have a air compressor, don't have a nitrogen bottle and regulator so I use good old air.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline
Old 08-18-2014, 10:50 AM   #16
mud yapster's Avatar
I used N in my racing bike tires but have my own N set up. I've always just used air for my other tires and they fluctuate pressure with temp do to the moisture in air expansion. I just check my tires before any trip and adjust the pressure as needed. I do use a electronic tire gauge that measures to the 1/2 pound so all my tires have same pressure.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline
Old 08-18-2014, 10:57 AM   #17
Love the auto spell check "Martians" that came on the iPad. They "maintain" a flair in my posts!
Old 08-18-2014, 10:59 AM   #18
My auto check always misspells my typing LOL
Old 08-18-2014, 01:26 PM   #19
Grape Escape
Wonder if helium or laughing gas work any better than nitrogen. Suckers born every minute.
Don't forget to get your windows etched.
Another make easy money scam for dealer profit margins
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline
Old 08-18-2014, 01:55 PM   #20
With nitrogen, your tire pressures will remain more constant, saving you a small amount in fuel and tire-maintenance costs. There will be less moisture inside your tires, meaning less corrosion on your wheels. You will not be able to feel any difference in the ride or handling or braking, unless your tire pressures were seriously out of spec and changing to nitrogen brought them back to the proper numbers.
Best reason is that most people do not check the pressure often at all, thus nitrogen is a good choice. For those that are anal about tire pressure, common compressed air will do.
As for me, the trailer tires came with nitrogen and I have two sources of nitrogen to maintain them that way, so I take advantage of that.
As with anything else, it is all personal choice.
Closed Thread
led, tire, tires
