Closed Thread
Old 09-02-2015, 11:23 AM   #81
dcheatwood's Avatar
I stand corrected. Been driving 47 years and never seen or heard of a rusted thru wheel. Driven one vehicle for up to 14 years, no leaks. Bought a 67 Chevy belaire in 1997 with original wheels. Drove it 4 years, no rust thru. Guess some issues can arise tho.
Seems I remember as a kid, my dad putting water in his back hoe tires, for weight I think. 😨 Must not have known about the moisture problem.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is offline
Old 09-02-2015, 11:30 AM   #82
(Dry Huunday)
DreiHunde's Avatar
Originally Posted by dcheatwood View Post
I stand corrected. Been driving 47 years and never seen or heard of a rusted thru tire. Driven one vehicle for up to 14 years, no leaks. Bought a 67 Chevy belaire in 1997 with original wheels. Kept it 4 years, no rust thru. Guess some issues can arise tho.
Seems I remember as a kid, my dad putting water in his back hoe tires, for weight I think. ��
Yup...my dad and all his farming buds did the same with tractors and swamp buggies to help with traction!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline
Old 09-02-2015, 10:18 PM   #83
Stop being a protagonist.
Huh?
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now
Old 09-02-2015, 10:19 PM   #84
Left Coast
Wow, why don't you tell us how how really feel! Calcium/water also worked...pumped alot.
bob caldwell is offline
Old 09-02-2015, 10:45 PM   #85
Iwannacamp's Avatar
I "think" the tractor tires were normally tube type tires. The water is in the tube. FWIW I have an old ??'66 2424 tractor that has a rusted rim around the stem and a 50 john Deere that has 2 bad front rims. Both have set for many years. I think that's what causes it mostly.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is offline
Old 09-02-2015, 10:46 PM   #86
Is there a technical chance of a problem? (Mythbusters answer) plausible
Is there a good chance of a problem in real world driving? busted
Look at it this way.
# of vehicles that used nitrogen for the last 100 years?
# of miles driven by those vehicles using nitrogen?
vs
# of vehicles that used compressed air for the last 100 years?
# of miles driven by those vehicles using compressed air?
I'll stick with the real world results over time.
Most people only own a vehicle for 10 years or less anyway.
madmaxmutt is offline
Old 09-02-2015, 10:59 PM   #87
2007 WildCat 32QBBS
05CrewDually's Avatar
Somebody drank the Kool-aid. And alot of it.
05CrewDually is offline
Old 09-02-2015, 11:10 PM   #88
schrederman's Avatar
At best 95% nitrogen?!?! what about that other 5 to 10%? Some folks just have to be right...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline
Old 09-02-2015, 11:11 PM   #89
SKnight's Avatar
Originally Posted by madmaxmutt View Post
A bit of an over reaction . . .
vs
There's actually a real chance of an issue. Is it every vehicle or will happen every time, no.
In my career there were probably five wheels that had significant corrosion and two steel wheels that actually rusted through. One rusted around the valve stem and it failed suddenly while going down the road. The other rusted around the welds where the center was welded to the outer rim and fortunately started leaking before it failed. Both had roughly a cup or so of water in the tire, the majority of the rust was internal, one that came from the same stand alone air pump at a local station. I went and checked it myself and it looked like a spray gun.
The majority of this can be prevented with air from a good source. I said N2, being dry, is nearly a must for those running balancing beads and will help with corrosion problems. Not that it's an immanent threat.
It's not kool aide guys. The benefits are well apparent in the primary industries where it's used, aerospace and racing. At our level the benefits are still there, it's up the individual to choose if it's good for them.
But some people just have to kick what they don't understand. The same was said about disc brakes too. Now, would you have a vehicle without disc brakes?
It's funny, I say that yes, it can cause an issue and you guys dogpile me.
Have your fun, I'm out.
SKnight is offline
Old 09-02-2015, 11:13 PM   #90
Left Coast
Well, it was 50 years ago!
Closed Thread
led, tire, tires
