08-18-2014, 02:44 PM
#21
Originally Posted by larryscsi
With nitrogen, your tire pressures will remain more constant, saving you a small amount in fuel and tire-maintenance costs. There will be less moisture inside your tires, meaning less corrosion on your wheels. You will not be able to feel any difference in the ride or handling or braking, unless your tire pressures were seriously out of spec and changing to nitrogen brought them back to the proper numbers.
Best reason is that most people do not check the pressure often at all, thus nitrogen is a good choice. For those that are anal about tire pressure, common compressed air will do.
As for me, the trailer tires came with nitrogen and I have two sources of nitrogen to maintain them that way, so I take advantage of that.
As with anything else, it is all personal choice.
IMO after all the posts on this subject (and there have been many including mine) this one is most complete and common sense one regarding using nitrogen or air in your RV tires. It's not complicated and gives you the facts you need to make your own decision regarding this issue.
The only thing left out was the outrageous cost of nitrogen servicing and the scarcity of finding places to take your money if you decide to use nitrogen.
Thanks for your post.
01-01-2015, 09:50 AM
#22
15 -21FBRS 17-F150 2.7 e
Heat is what causes the rise in pressure. I work in the NASCAR ranks. We use nitrogen. We still have pressure build up. However it is not near as much as compressed air due to the moisture content. I run air in my TT tires and check them frequently.
01-01-2015, 12:38 PM
#23
Anacortesians
Based on my research into tire bursts on Boeing airplanes, you don't NEED nitrogen unless your rig can accelerate to 150 mph in a mile and a half and then fold its wheels up into a metal box.
I did find one incident where a main gear tire on a 727 blew out and ripped an 18" hole in the wheel-well bulkhead. It it hadn't been for a couple of USPS mail bags jamming in the hole, we might have lost the airplane.
The beads of the tire had failed in tension. One of our structures gurus calculated that the instantaneous pressure in the tire was about 12,000 psi and that it resulted from an explosive spontaneous combustion of gases that came out of the tire material.
It turned out that the airplane had taxied about 3 miles to the end of the runway and then taken off, all the time with a dragging brake. That particular airline hadn't bought the optional brake temperature monitor system, which I think became a standard feature on later airplanes.
Frank and Eileen
No longer RVers or FR owners
01-04-2015, 07:24 PM
#24
Paul & Sheri
Nitrogen atoms are larger than Oxygen so they're less likely to leak. I don't think I've had to add "air" but maybe three times in the three seasons I've had nitrogen filled tires and only a couple of pounds. Big difference from air filled tires.
Now if I could only get past the inconvenience and cost to fill them with nitrogen. It's the K-cup syndrome. I love Kurig coffeeys but not worth the 60 to 75 cents per cup plus the expensive coffee maker.
I'll continue to use my own compressor and re-fill the tires with air and buy Chock Full O' Nuts coffee.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
01-04-2015, 08:33 PM
#25
Nitrogen filled tires are the second biggest lie told to the American people.
2013 Berkshire 390BH
01-04-2015, 08:47 PM
#26
X2. My tires are 79% nitrogen already.
2011 Traverse LT, 3.6L, FWD
08-25-2015, 08:55 PM
#27
is there a different method to check the pressure? or can I use the same gauge I use for air?
08-25-2015, 09:42 PM
#28
No special gauge for checking.
But, you should think about this,
The air we breathe is 78-79% nitrogen now, if you fill a tire with air the "smaller" air molecules will leak out, eventually even after topping off only the "air" will leak out and you should only have "free" nitrogen left inside the tire.
Nitrogen, one of the "biggest" scams going!
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
08-25-2015, 09:50 PM
#29
When you check it you are going to (Expell the Nitro)! What are you going to use to Refill? Yes it takes the same gauge! Youroo!!
08-25-2015, 09:57 PM
#30
Man, I was hoping we'd KILLED this subject!
08-25-2015, 10:11 PM
#31
No, It lives on!!
I run Nitrogen in all my tires! It is free here, no extra charge when topping up.
B and B
08-25-2015, 10:13 PM
#32
What is the first?
B and B
08-25-2015, 10:18 PM
#33
Its a VIRUS! Youroo!!
08-26-2015, 06:52 AM
#34
(Dry Huunday)
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
08-26-2015, 06:57 AM
#35
B&B were do you get free nitrogen. The places I have had tires done want to charge me.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
08-26-2015, 08:01 AM
#36
Go to your local welding shop and rent a tank of nitrogen.
Don't forget to buy a regulator tho.
I think the one time deal for our tank was $200.00 for the tank filled.
There's hundreds of fill ups per tank!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
08-26-2015, 11:28 AM
#37
If I wanted to do that I would just fill up at work, we have a 40 foot high liquid tank outside.
Ontario
08-26-2015, 11:33 AM
#38
This is the "Walking Dead" subject... you really CAN kill it... but it comes back anyway. Some folks just can't accept that it's a scam.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
08-26-2015, 11:38 AM
#39
Nitrogen works, there's no denying that. Aerospace, racing, general aviation all have proven it's benefits.
The question is, how necessary is it at the grassroots level? Rule of thumb is that regular air increases in pressure 1PSI for every 10* increase in temperature. A tire typically heats up about 50* over ambient, so we're looking at a 5PSI increase in pressure. I guarantee that you line up 10 gauges you'll see a 5PSI variation between them, and in reality 5PSI is negligible. Nitrogen does change, physics still applies, but it's on the order of .1PSI for every 10* increase.
Nitrogen doesn't leak like regular air does. I've proven it myself. My motorcycle still has 41PSI in the tires two years later, my truck was a rock solid 65-80 for two years before I replaced the tires. So there is that.
Some say it rides better. Personally, I think it does.
Lastly, it's bone dry. For those running balancing beads it's almost necessary. I like that the wheel isn't exposed to moisture. Moisture reportedly can harm the inner lining of the tire though I can't say I've ever seen that one.
The benefits are provable. The question is, do we need it in our everyday cars, trucks and trailers. Do we need aviation technology in our personal lives?
Many asked the same question about disc brakes. Sunday I tested my disc brakes very hard towing my camper on the way from Bristol, I promise, disc brakes and ABS helped keep me out of the ditch.
It's up to the individual. Personally, I have no problem with pure nitrogen. I don't mind paying the first time as I know the process to purge out air and get to a 95% N2 state is time consuming. I'm looking for a small tank to top up with at home, I just haven't spent the money.
Much like the running premium fuel in your 87 octane rated car. Does it help? No, certainly not enough to offset the cost. The extra detergents will help clean things, but that's about it.
So it's up to the individual to make up their own mind. It it worth it? I think yes, provided you don't pay through the nose for it. Will it perform miracles and net you 10MPG, no.
08-26-2015, 12:00 PM
#40
Originally Posted by B and B
No, It lives on!!
That's partially true in Oshawa. It's free if you purchased the tires from that vendor, otherwise others will charge for a top up.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
