Old 07-18-2013, 08:34 AM   #21
Wanna Be Camper
SaskCampers's Avatar
Originally Posted by Dave_Monica View Post
All Rockwood/Flagstaff 5vers come with C rated tires and 4000 lb axles. This is the 4th year and 10000 + miles on the Duros that came with the camper and they seem to be wearing just fine. I am however thinking about replacing this fall with Maxxis or Marathons on our NH trip as they're harder to get in Ontario.
Isn't that how the manufacturers determine the camper's GVWR...axle rating x 2 plus dry pin weight?
Dave
18,000 and 4 years on our Duro's and they are wearing fine as well. They will be replaced before the next major trip though. I have not even had to add a lb of air to any of the 5 tires in 2 years either. FWIW, I keep ours covered with tire covers when ever the unit is sitting for any amt of time and they have been balanced with the TST TPMS sensors on them.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 07-18-2013, 09:19 AM   #22
Scratch's Avatar
After completing a recent long trip (2900 miles), we now have 3600 miles on our TowMax Power King ST225/75R15 tires (DOT date coded the 33rd week of 2012). Lots of bad roads encountered and I must admit that I was concerned about the tires throughout the journey. I inspected them and checked tire pressures daily. They seem to be OK at this point, but after reading so many poor reviews, we intend to change them out with a set of Maxxis tires before the 6000 mile mark.
Scratch sends...
'12 nights camped: 12
'13 nights camped: 24
'14 nights camped:
Scratch is offline   Reply With Quote
Old 07-18-2013, 09:21 AM   #23
My Duro 2100 radials are anything but cheap. Average 1 lb pressure loss per year, 3 years old, 6000 miles and still look brand new. With all the cheap china tire talk around here you would think that the highways would be littered with broken down trailers.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 07-18-2013, 09:35 AM   #24
As stated before, all st tires are made off shore in the far east. Some say the Maxxis are not made in China, but that is just a matter of semantics. Whatever the argument, stick with a major brand like Maxxis, Good Year etc. and you won't have near the problems. Keep in mind, just because a tire looks good, does not preclude a blowout and major damage to the trailer. If you can afford it, definitely get a TMST system and go for the next higher load rating, if you have factory C rated tires, go with D rated and inflate to max sidewall pressure to reduce heat and wear as low pressures will definitely increase temperature and as such, increase wear.
Old 07-18-2013, 09:43 AM   #25
Wanna Be Camper
And thems the facts Jack.
John & Deb
Old 07-18-2013, 09:48 AM   #26
I agree that the Duro tires don't seem to have the bad rap that so many others do. The main reason I bought the Maxxis tires was to step up to a D-rated tire. If the Duros had been D's, I may not have changed.
Dave
Yes, you are correct. I guess what I should have said is that my gross weight is approaching the rating of my axles, as the GVWR of my fifth only allows about 1800 lbs of cargo. With well over 100 gallons of water/waste capacity, it wouldn't take much to exceed that allowance. (I know nobody runs with full tanks).
When we were shopping for a new fifth, the Sabres had much heavier axles, even though the camper itself didn't weigh much more. From memory, that fifth had a cargo capacity well over 3000 lbs, so the axles would obviously never be overloaded.
Sorry for the confusing post.
bakken is offline   Reply With Quote
Old 07-18-2013, 05:16 PM   #27
New tires
First thing this morning I towed my limping Flagstaff to the local tire dealer. They installed 4 new Carlisle load range D, 8 ply sidewall radials on it. As I was driving out of the drive UPS was unloading a replacement for the seperated one. Those tires from Forest River are REALLY cheap junk. Light weight and flimsy off of the wheel. Mine were TrailExpress branded, also says Power Towing on the sidewall. Thanks for all of the input. We are safer now.
FordHauler is offline   Reply With Quote
Old 07-19-2013, 09:20 PM   #28
rambilt's Avatar
My tires are also made from China and they are C load ratings... That really sucks!!
rambilt is offline   Reply With Quote
Old 07-19-2013, 09:26 PM   #29
You will find all ST tires are made in the far east. China, Korea, Taiwan, etc. As Herk said on a post, there's not many rubber trees in the US.
Old 07-19-2013, 09:36 PM   #30
If anyone could ever find the specs for some of these factory tires, it might be very revealing. If your original tires were noticeably 'light weight and flimsy', the specs would verify that.
But just try to find specs on any of them.
