Old 12-11-2013, 09:12 PM   #1
Toilet bubbling
Question:
My toilet is bubbling when I flush it. I thought that may have been the "burping" that I heard about when the black tank is full. I emptied the black tank but the bubbling/burping continues. I have my tank heaters on, does that cause bubbling/burping? If not, any guesses?
2014 Ford F250 Lariat
2014 Rockwood Signature Ultra Lite 8280 WS
2023 Forest River Rpod model 201
Louisiana before, fulltiming since April 11, 2014
blog--- www.gozatravels.blogspot.com
Darrell is offline   Reply With Quote
Old 12-12-2013, 10:29 AM   #2
AKA: 'tiredTeacher
awellis3's Avatar
Sounds like a vent problem.
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 12-12-2013, 11:07 AM   #3
5 hole's Avatar
You have the rare 'Cauldren option' Sorry could not resist... sounds like venting issues to me too?
5 hole is offline   Reply With Quote
Old 12-12-2013, 01:29 PM   #4
A poop pyramid might be forming. No I'm not trying to be funny. Try pouring a 5 gal bucket of water as fast as you can down the toilet to break it up.
Wiscampsin is online now   Reply With Quote
Old 12-12-2013, 02:23 PM   #5
BamaBob's Avatar
Originally Posted by Darrell View Post
Question:
New RV I see....how have you been handeling the Black tank when you were camping (i.e. were you hooking up to a sewer and leaving the black tank valve open all the time?)
Here is a permalink to some tips on Black tank maintenance and cleanout:
http://www.forestriverforums.com/for...tml#post507704
HTH!!
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 12-12-2013, 06:38 PM   #6
Thanks guys. I'll check the vent to make it is clear. I only dump the tanks when they get full. I've only had to dump them 2 times since I picked up the RV a few weeks ago. I'll give ya'll's suggestions a try. I just need to make sure I'm not sitting when I flush or I'll get a surprise.
Old 12-12-2013, 06:47 PM   #7
Remember water is your best friend, if you do not have to ration water you are better off using more rather than less.
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
Bill m is offline   Reply With Quote
Old 12-12-2013, 07:03 PM   #8
Thanks everyone. I found another thread with an identical problem. It was from cdnwillyg. I believe my problem originated when I used the black tank flush and pushed something up in the vent, blocking it. I'll see what can be done to clear it. Maybe a short drive with the tank half full and maybe with 10 pounds of ice in the tank before I pull out.
Thanks again everyone.
Old 12-12-2013, 07:06 PM   #9
Ford Idaho's Avatar
Have you tried running some water down the stack yet?
Old 12-12-2013, 07:28 PM   #10
I was going to suggest the same thing especially if you have a straight adjustable nozzle and have someone turn the water on after you shove the hose & nozzle down the stack.
Old 12-12-2013, 07:43 PM   #11
Ford Idaho's Avatar
A trigger nozzle would be handy.
With luck a little water weight will be enough.
Old 12-12-2013, 07:51 PM   #12
Don't know how you'd get a trigger nozzle down the stack.
Old 12-12-2013, 07:56 PM   #13
Ford Idaho's Avatar
No need.
Just point and blast, it would be what about 8-9 feet straight down.
Old 12-12-2013, 08:01 PM   #14
No need.
I was figuring on shoving the straight nozzle down and actually into the tank and let it blast away at a possible mound.
Old 12-12-2013, 08:08 PM   #15
Ford Idaho's Avatar
Ah, that would work.
Old 12-12-2013, 09:11 PM   #16
It's working now. It was an old-fashioned clogged drain pipe. I noticed it when the tank was empty but the water in bowl would only go down real slow. I broke loose the connection of the sewer pipe where it goes into the ground and that should have given me positive ventilation in the tank,,,,when the water in the bowl wouldn't go down, I figured it was a clog at one of the bends. Probably from a bad ratio of paper to water. I didn't think I would need a plunger after moving into the RV, I was wrong, so I had to run to the store to get one. Got a fancy one, it cleared the clog. I'm back in business. Thanks again for ya'll's help
