10-29-2017, 08:31 PM
Toilet leak at occasional flush
Toilet is collecting water at the base of the unit on the floor. I have traced it to around the bolts holding the tank to the floor. Bowl is never low , so I think I narrowed it to an occasional flush. The toilet is porcelain not plastic with no obvious damage , and no water leaking from toilet lines either.
Could this be the toilet flange or rubber gasket under the toilet that acts like a " wax ring" ? ( I know RV toilets don't have wax rings)
Easy fix? Replace both parts?
Anyone have any of these issues?
2016 RW 8312 TT
THANKS
10-29-2017, 08:54 PM
What brand of toilet? Could be as simple as snugging up on the hold down nuts.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
10-30-2017, 07:29 AM
As time goes by the leak will only get worse. No repair kit to fix it. Just go ahead and switch it out with a new one. Been there done that.
Jim and Sherri Brown
2013 Silverado 2500 6.6 DuraMax
2012 Sabre 34REQS6
10-30-2017, 07:33 AM
Replace the toilet?
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
10-30-2017, 08:29 AM
Domestic, the camper and toilet is new, really?
10-30-2017, 08:35 AM
Dometic , dam spell check
Disconnect the water line and remove the 2 nuts and pull the toilet so you can see the gasket. It may have folded under when installed or slipped somehow. It only takes a few minutes to remove and reinstall.
10-30-2017, 03:03 PM
New gasket probably in order.
Simple fix.
Don't over tighten.
MB
10-30-2017, 04:20 PM
Thank you for the response!
10-30-2017, 04:48 PM
Just as confused as you
Do you have a regulator on your water line? I have a Dometic 310 and if the water pressure is above 40 psi the water coming out of the one hole at the rim goes down the side of the bowl. Funny it's just one hole that does it. Before anyone says anything, the 310 has a china bowl and doesn't actually have a rim like the toilet at home. With the toilet seat down it's easy to miss what's happening.
Richard & Jill
10-30-2017, 11:03 PM
Ditto, what he said. But I am not convinced of where my occasional clear water TRICKLE comes from.
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
10-31-2017, 07:18 AM
Scrapper, I had your problem on another rig. Water bubbled and spit coming out.The hole was formed wrong. I used a small caliber brass brush (like comes in a cleaning kit for unmentionable big boys toys) on my first attempt at a fix. That removed residue and helped some, but in the end I just epoxied that opening closed. Good luck to all.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
10-31-2017, 10:10 AM
I do have a water regulator. Thank for all the positive responses [emoji1303]
11-06-2017, 03:29 PM
Related question, My Dometic bowl seal leaks, can't keep water in the bowl. Where can I ind a replacement seal? Easy to change? Thanks
11-09-2017, 03:18 PM
I just recently experienced the same issue with water around the base of the toilet last weekend. I was able to track down the leak to the supply line right where it enters the toilet.
To remedy the situation I unscrewed the supply line nut, removed the supply line, cleaned all the surfaces and reassembled.
This solved my issue and I have determined that the leak was a result of the recent cold weather and the contraction of the plastic pipe and fittings.
2013 Rockwood Freedom2381G
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
