Old 09-24-2014, 07:50 AM   #1
Tongue jack quit working on 2014 8329ss
We hooked up this past Sunday at the campground we had been camped at for a week. Everything worked fine. We had a six and a half hour drive home trough several rain storms. When I tried to used the jack it would not work. I used the crank to unhook.
I checked the jack with a meter and had power into the jack and through the switch.
On Monday I called the dealer and they told me to either bring the camper to them and they would take care of it or take the jack off and bring it to them. I took it off and did the fifty mile drive on Tuesday. Without any problems they gave me a Husky 4500. The old one was a 3500.
Since I have the diamond package I will have to paint the new one black.
Has anyone else had problems with their tongue jack?
psrujak is offline   Reply With Quote
Old 09-24-2014, 09:12 AM   #2
I had a problem with my jack as well. What i found was that water would enter pass the level bubble on the jack. The water would then get into the gear assembly and then get into the motor. I found this out when my jack wasn't working when i was setting up for a weeks stay in Lancaster PA. I ended up taking it all apart including the motor and cleaned it. I reassembled and was back up and working. Since then i keep a cover on it and haven't had a problem since. Just a bad design over all i think. I would invest in a jack cover to protect the new one.
bobmart5705 is offline   Reply With Quote
Old 09-24-2014, 09:29 AM   #3
mark0224's Avatar
Too cheap to buy one of the electric jacks I made a part so I could use the drill I put my stabilizers down with and now I use the drill to do my work. Part cost less than a dollar.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 09-24-2014, 09:58 AM   #4
raspivey's Avatar
Same here a few months ago. You got luckier than me, my motor had completely seized up and I had to take it apart to manually crank it off the truck.
Old 09-24-2014, 10:16 AM   #5
wmtire's Avatar
Yes, water infiltration can be a problem as well as some brands are more known for problems. Do a search here for Lippert/LCI tongue jacks and you will see this.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 09-24-2014, 10:29 AM   #6
I started putting a 5 gallon bucket over my jack with the chains holding it down. Not sure who posted this idea first, but its alot cheaper than buying a jack cover
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 09-24-2014, 10:44 AM   #7
bobmart5705 What campground did you stay at in Lancaster? We were at Lake in Wood in Narvon Pa
Old 09-24-2014, 12:49 PM   #8
psrujak, we stayed at Spring Gulch campground in New Holland,P.A. We usually go around the end of August every year. Like Mountndream stated, a 5 gallon bucket works just as good and is cheaper.
Old 09-24-2014, 08:36 PM   #9
raspivey's Avatar
A bead of silicone around the bubble level works also...and there's no bucket to mess with. The only time you ever need to open it is for greasing the jack once or twice a year and all you have to do is twist and pull. Peels right off. I just started doing that on mine.
Old 09-25-2014, 09:39 AM   #10
Jack Cover
I have a 2109s with electric tongue jack. I went to Dollar General and bought a waste basket and use it with two ball bungie cords to hold it on over my jack motor. Cost- $1.50
bojangles is offline   Reply With Quote
