01-15-2018, 01:13 PM
Torsion bar axle or leaf springs
Buying a new travel trailer in the spring. Looking at Rockwood &Hemisphere. The Rockwood has torsion springs and the Hemisphere has springs which are the better & what's the difference. Thanks & Happy camping.
01-15-2018, 01:54 PM
I have trailers with both
I have a Rockwood Mini with a Torsion Bar setup and I love it. Less bounce than a leaf spring model and simple. No spring shackles, spring hangers, or leafs. since there is no spring shackle or center bracket to jack up on you do have to jack on the trailer frame for changing tires or doing bearing service.
I think the Torsion bar rides smoother but that is only a feeling since no one travels in my trailer when going down the road.
My former TT was a 1983 StarCraft popup with Torsion bar and I actually had to build a bar to pry the tire down a bit so I could get if off the trailer. Probably in 30+ years it had sagged a bit?
I notice that the high end leaf spring trailers have shock absorbers on them.
Choose the floor plan and features you like and then take whatever undercarriage it comes with.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
01-15-2018, 02:03 PM
Thanks for the reply grandpa, the leaf springs probably have more bounce than being smooth like the torsion bar.
01-15-2018, 05:15 PM
One advantage of leaf springs is the equalizer - the trailer can be towed slightly nose up or nose down without changing the load distribution on the 2 axles. With torsion axles it's important that the trailer is towed level to prevent overloading one of the axles. And, yes, torsion suspensions can sag over time. It's easier to replace sagging springs.
01-15-2018, 08:06 PM
The torsion bar axle set up is better by far. I’ve had both. Better ride, no broken parts, no wore out bushings, no noisy springs. My leaf springs are on boat trailers so the leaves will rust and squeak because they get dunked underwater. I don’t think having a torsion suspension should be a deal breaker, but if you buy leaf springs, add shocks and be ready to do maintenance like greasing, replacing bushings ect. Jay
01-15-2018, 08:25 PM
Thank you for all the replys, I guess I will pick my favorite floor plan & go with the running gear it has,just like grandpa said.
01-16-2018, 01:59 PM
Agreed, torsion bars ride better. I've only had them on a utility trailer but I like the handling. Bounce is reduced, but still evident. Does anyone know if shocks can be used with torsion bars?
01-16-2018, 02:29 PM
I own a MiniLite with torsion bar suspension and I like it very much.
From what I learned the torsion bar trailers sit about 6 inches lower than a leaf spring trailer. This helps with stability ie lower center of gravity. In my case it was the difference between inside storage or having to leave outside.
01-16-2018, 02:33 PM
I suppose shocks could be added to anything if so minded.
Just remember, torsion axles are self-dampening by design.
I'm guessing you haven't loaded your utility trailer enough to get the full effect of the torsion axle's benefit.
01-16-2018, 02:37 PM
My Pace car carrier has torsion axles and I really like it, nothing ever moves around inside the trailer. My Puma 5th has springs and no shocks (yet) and it moves everything from point a to b and back again. If you have I choice, I would recommend torsion axles.
Retired Auto body teacher
2021 Arctic Wolf 3550 Suite
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
01-16-2018, 02:45 PM
Springs
Torsion bars. I think they use them on Airstream too.
01-16-2018, 02:46 PM
Torsion bars are used by Airstream.
01-16-2018, 02:56 PM
Airstream started using torsion axles around 1960 they had shocks! Dexter now supplies the airstream torsion axles with shock kits for the backing plates and shock mounting studs that weld to frame! Youroo!!
01-16-2018, 03:08 PM
If you are full time buy an RV with at least 5/8 inch thick floors.
01-16-2018, 03:22 PM
01-16-2018, 03:43 PM
Many horse owners will not let horses ride in a leaf sprung trailer any more....Torsion or air bag only. Leaf springs are hard on a hoses legs.
Torsion suspension by its very nature is independent suspension. One wheel hit a hole the other end of the axle isn't affected.
Torsion is the only way to go if you have a choice.
01-16-2018, 04:09 PM
I have an ACE boat trailer for a 30 ft. REGAL with torsion and I have seen torsions hold up much better over time, especially when exposed to salt. I wish they put them on my Cottage
01-16-2018, 05:14 PM
Huh, didn't know they did that. That's pretty cool, if I had known about that, might have added shocks to ours 2 years ago... Thanks for the info!
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
01-16-2018, 05:30 PM
I would go with the floor plan that you like the best and not worry about the suspension.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
01-17-2018, 04:00 PM
And if you find the floor plan you like WITH torsion suspension it's a win/win. That's what happened to us!
