12-19-2017, 08:32 AM
#21
I pull my 2014 8289ws with a 2013 Toyota Tundra
2014 Rockwood 8289
2013 Toyota Tundra
12-19-2017, 11:53 AM
#22
What kind of trucks do you have across the pond?
2019 Ram 3500 DRW HO Cummins, Aisin Trans and 4.10 gears.
2017 Flagstaff 8529 IKBS Classic Platinum Edition
12-19-2017, 12:48 PM
#23
Most are European however they are embodied into the UK market, Ford Ranger wildtrac 3.2 Lt is the one that's seems top of the pile and being adopted as to pull the 5vers , others are Nissan Navara and the new Volkswagen , the aim by the manufacturers is to achieve 3500 kg towing, the Ford is plated for this weight, with adding air support we are able to replate allowing a train weight 7ton , the US ton is different to a UK ton. Some of the hardened 5th wheeler owners cut down wagons and large trucks and fit hitch's.
12-19-2017, 12:51 PM
#24
To import a new 2500 truck form US besides the vat and transport cost , the the government add another 20%, if it 10 years old 10%, so roll on Brixit, and let get down to deals.
12-20-2017, 12:16 AM
#25
I am surprised that no one has picked up that you use the British Long Ton (approximately 2240 lbs, slightly more than the Metric Tonne, 2200 lbs), which is heavier than the U.S. Short Ton (2000 lbs.)
12-20-2017, 01:46 AM
#26
Whaaaat?
Now I have to figure out what you just said. Who knew a ranger would be the best at pulling a 5er...I hope they make them bigger over there.
Good luck!
12-20-2017, 04:48 AM
#27
We have been deliberating the tow for the 8289ws in UK this a quote from one member....,
Rockwood 8289ws is apparently 8866lbs unladen/unmodded. Cargo is 1354lbs, so all-up max weight is 10,220lbs. Or 4,636kg.
This is a tad more than say a Rambler (4,200kg on older model) but that means almost ANY Euro pickup will pull it, such as Navara, Amarok, Wildtrack etc. The Amarok V6 and Wildtrack 3.2 will pull a little easier.*
Irrespective of US/Euro truck debates, every truck has a max possible towing weight. Euro trucks are 3000-3500kgs typically. Some US trucks are the same, and the bigger ones can tow a lot more. This is why many trucks may need uplating and modifying as a 3500kg towing limit is just not quite enough for many fivers.
A US truck that can tow more than the weight of one's fiver 'out of the box' may not need modifying or uplating, but there are other issues with these, tax on importation being one, so some need downplating! Some of this thread has been about total all-up weights and licenses, which is kind of separate.
12-20-2017, 04:50 AM
#28
Originally Posted by dbledan
Whaaaat?
Good luck!
I suspect that will never happen ,I think your Ford 1500 would be the problem
12-20-2017, 05:00 AM
#29
Just a member
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
12-20-2017, 07:29 AM
#30
Sorry I don't understand your comment please elaborate
12-20-2017, 08:56 AM
#31
Canadian Member
Frankrose, I recommend that you focus on the payload (load carrying) capability rather than towing (pulling) specs of any trucks you’re looking at.
Are there any clubs over there for owners of U.S.-manufactured 5th wheel camping trailers? Unless there is someone on this forum that’s very familiar with European trucks, the people on a European camper forum may be able to offer you more assistance in picking a tow vehicle than we can on this side of the pond. Even your hitches may be different than over here for all I know. But you’ll get lots of great advice here on how much a 8289WS actually weighs when loaded for camping, and how to maintain a U.S.-manufactured 5th wheel.
12-20-2017, 09:59 AM
#32
The Reese hitch seems to be vogue at the present time, due I guess to short bed.
12-20-2017, 01:52 PM
#33
frankrose, Your OP indicates a problem from square one. You have ordered a 5er in a country that appears to have a limited availability of of tow vehicles, at least not the options we share on this side of the pond. The cart before the horse thing comes to mind here.
Not that you have done anything wrong and it's nothing a deep pocket won't cure. But not having dealerships representing the Big 3 at every turn (as we do here) you have made the quest for the proper TV an uphill climb. As you stated, the cost (transport and taxes ect...) of getting a 2500 size TV into your country makes that an expensive option.
Maybe reevaluate and find a TV that meets expected requirements first. One that is easily serviced and supported with parts and maintenance.
RMc
12-25-2017, 06:31 AM
#34
We haul all this with a 2500 gmc 6.2 gas with no problem.
01-12-2018, 06:50 AM
#35
I have a 2017 8289WS and pull it with a Ram 2500 6.4. I really want to pull the trigger on a Cummings but can't justify it
01-12-2018, 07:36 AM
#36
I pulled mine with a 2017 gmc 2500hd Denali duramax. It pulled effortlessly had power to spare. Got 11 mpg down to Florida from Canada. Very pleased with the new diesel. Well worth the investment besides with all the promotions that go on you can get the diesel option for free. GMC had 20% off MRSP just recently.
Sent from my LG-D852 using Forest River Forums mobile app
01-12-2018, 08:17 AM
#37
Whaaaat?
Good luck!
Middle class access to V8 engines and 3/4 - 1 ton Pick ups happens only in America and in very few places in the world.....
I have a Japanese friend and he said that Toyota have the Tundra only in/for America....
In other places, you need to get the job done with Rangers, S10s and Tacomas and those trucks are considered luxury....
Not too long ago, in a UK Camping magazine the BMW X5 was quoted as one of the best HD towing vehicles.....
So as someone that challenged the American consensus and towed a 23IKSS with a X5 for 12K miles, I would recommend the OP to keep to the numbers and get the smallest truck that he is comfortable/safe with.
Imagine he tows his 5er to Portugal or Italy and then you need to maneuver that F350 in Lisboa or Rome....
A new F150 would/could be considered an overkill for that 5er in the UK but the new ones have very good payload capacity if you order with the HD payload package and, depend on the version, are not so big/long/tall as their big brothers .....
2018 F150 XLT V8 HDPP
2018 Rockwood 2909WS
" Life is simpler when you plow around the stump..."
01-12-2018, 08:33 AM
#38
Having a larger towing truck is all well and good, but this does not increase the payload of the 5ver, on the Rockwood 8289ws the payload is not so great, again this can be challenged with respect to holiday period spent away from home against fulltiming , which ever way you look at it the axels are the limiting factor/ manufacturer permitted gross load. One of the issues we have is having a the 5ver fully loaded this then increase the pin weight which impacts of the tow.
01-12-2018, 08:53 AM
#39
Hi nice looking set up, question with the boat on the back what weight is being placed the 5ver axles? normally the pin weight would I guess10/20% of load of 5ver thus reducing Axle weight,in your case you are reducing the pin weight and increase Axle weight, it would be interesting to no the ball weight of the boat, again guess with 5ver full loaded and boat attached the Axle weight on the 5ver may be over the gross permit able , now applying this in the UK you would no longer be insured and no doubt contravene several laws, unfortunately we have a very perceptible law.
Thanks for sharing your photo.
01-13-2018, 11:42 AM
#40
Truck
How about a small lorry. Volvo, Mercedes. Would take some modifications.
