Old 12-08-2012, 12:04 AM   #11
Lynkage's Avatar
Originally Posted by Twisty View Post
The payload rating of the truck could be as high as 3030 lbs.
That would only be for the 4X2 Reg Cab.
2010 SuperCab 4x4 Payload GVWR
133" 5.4L 3-valve 1020 6950
145" 4.6L 2-valve 1480 6900
4.6L 3-valve 1550 7000
5.4L 3-valve 1670 7200
5.4L 3-valve 1960 (2) 7700
163" 5.4L 3-valve 2350 (1) 8200*
(1) *Requires Heavy-Duty Payload Package.
(2) **Requires Max. Trailer Tow Package
op says short bed but which one? 163 is a long bed.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 12-08-2012, 09:20 AM   #12
Jmjtx's Avatar
Originally Posted by troyt View Post
Had a 1/2 w/ Hemi pulling a 34ft 7,000lb loaded TT. Pulled fine on most roads, horrible gas mileage and not so good on the hills. Have a 3/4 w/diesel and would never go back. Handling is night and day. I feel much safer. Just my opinion.
But got a great deal on my 3/4 or I guess I would still be driving my 1/2 ton. Sometime miss it
Ditto going from 1/2 to 3/4 pulling 26' And now 31'....ditto on missing the HEMI at times, but not crying!
Jmjtx is offline   Reply With Quote
Old 12-09-2012, 03:57 PM   #13
Jjsav's Avatar
Just pulled my 2013 Rockwood 8281SS home on Friday 12-7 with my 1/2 ton and it pulled just fine. Pulls much better than my TT and truck has plenty of power. I am with you. Good luck and Happy Camping!!!!
2018 Jayco Eagle 355MBQS
2013 Rockwood 8281SS 5W, Reese Revolution (sold)
2016 GMC 2500 Denali HD 6.6 Diesel
2016 Victory Cross Country Tour
2012 Toyota Tundra Crew Max (sold)
Jjsav is offline   Reply With Quote
Old 12-13-2012, 01:18 PM   #14
I have been pulling our Rockwood 8280ws for 20 months. Our truck is a Ford F150 Supercab 8 ft. bed with the heavy duty cargo pkg. 5.4 triton gas engine with a 4.10 limited slip rear axle. I added a set of Helwig helper springs before picking up the new rv. We have been all over Texas, New Mexico and Arizona with no problems. The set-up is level and pulls fine. Sure the rig will not go up Monarch Pass in Colorado at any great rate of speed, but it does just fine at the posted speeds and a higher rpm setting which the engineer at FMC stated it was designed to run at all day with no damage. I hope you have a good time traveling with your rig.
Tom-s
Tom-s is offline   Reply With Quote
Old 12-13-2012, 01:23 PM   #15
Dave_Monica's Avatar
Originally Posted by Tom-s View Post
I have been pulling our Rockwood 8280ws for 20 months. Our truck is a Ford F150 Supercab 8 ft. bed with the heavy duty cargo pkg. 5.4 triton gas engine with a 4.10 limited slip rear axle. Tom-s
Are you talking about a heavy-duty payload option on your truck? Is the GVWR for it (on the driver's door post) indicate 8200 lbs?
Dave
Old 12-13-2012, 05:17 PM   #16
TURBS's Avatar
interesting post .
sub
turbs
Old 12-17-2012, 05:08 PM   #17
5er_tom's Avatar
I tow my 8289WS with a Ford 250 diesel. I would not consider using a ˝ ton truck.
Tom
5er_tom is online now   Reply With Quote
Old 12-23-2012, 07:12 PM   #18
Paul & Sheri
pwb01's Avatar
F150 ecoboost, 6 cyl. Doesn't slow me down even on hills. Good mileage too.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
