Old 05-17-2016, 03:11 PM   #1
Croaker's Avatar
Trailer Break-Away
My Break-Away (Orange/black stripe wire) is wired to the Switched side of the main 12v. Shut-Off.
Seems incorrect ??
What if you forgot to turn your power on ?
Croaker is offline   Reply With Quote
Old 05-17-2016, 04:26 PM   #2
Head Rambler
The break-away switch should be wired more or less directly to the battery. Are you sue it's to the switched side and not the supply side?
If it is wired to the switch side, I'd change it to the supply side.
Gotta go campin!
Old 05-17-2016, 08:01 PM   #3
Croaker's Avatar
The only wire on the battery side is the battery wire. The breakaway is on the switched side.
My trailer is only a few days old.
Old 05-17-2016, 08:17 PM   #4
Originally Posted by Croaker View Post
The only wire on the battery side is the battery wire. The breakaway is on the switched side. My trailer is only a few days old.
Picture shows it's on an auto reset breaker. Nothing wrong with it.
Old 05-17-2016, 08:38 PM   #5
Canadiancrew's Avatar
I don't see how you see that. If the big terminal on the left that has one wire that goes to the battery the other wires all go to the second terminal on the right.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 05-17-2016, 08:40 PM   #6
All I can say is it is an auto reset breaker. All trailers are supposed to/should have them.
Old 05-17-2016, 08:51 PM   #7
Croaker's Avatar
Old Coot.....it has a red handle on it....it says "ON"...."OFF" on it.....the back side of it has two copper posts.....one with a wire going to the battery....and the other with several wires stacked on it.
Looks like a Switch.....Smells like a Switch....
Nice boat CanadianCrew.
Old 05-17-2016, 08:59 PM   #8
Closer look and you're right, just unhook the break away wire to the other post. There should be a auto reset breaker somewhere in the line.
Old 05-17-2016, 09:12 PM   #9
wmtire's Avatar
I guess one advantage of having it on the switched side, is if a kid or dog pulls the pin out (which we have happen a lot). As long as the switch was on/disconnected while parked and not in use, then you wouldn't have to worry about the trailer brakes energizing or the breakaway switch melting.
I have actually seen many trailers with a disconnect switch at, or right at the positive post of the battery. Ones wired that way (either factory or afterwards) still are in the same boat as the OP, and must make sure the disconnect is connected to allow power to get to the breakaway switch, which would be downline from the battery when towing the RV.
2011 Flagstaff 831 RLBSS
I like to think of myself as a perfectianist...
Old 05-17-2016, 09:25 PM   #10
I was about to post a rebuttal to your last post as it has a red key sticking out the other side. Anyway.
Orval and Yvonne
trailer, breakaway
