Old 06-03-2014, 06:31 AM   #21
Your missing the point. The trailer is NOT dragging to the point where the wheels are lifting off the ground. It just scrapes the driveway a short distance. After my trip I am going to order drag wheels that will be mounted in the area of the stabilizer jacks. The drag wheels will not lift the back of the trailer anymore than the stabilizer jacks will and they will not be welded to the frame.
Thanks for everyone's input.
psrujak is offline   Reply With Quote
Old 06-03-2014, 07:01 AM   #22
TURBS's Avatar
I agree with youroo.
I have to put boards down to get the Sabre in and out of the shop.
You can see the grade coming out drops off quick.
I took this picture just before laying boards down otherwise my stab plates drag.
I think 3" wheels would be a bad idea on my trailer and it has an 11" "real" I beam.
I wouldn't recommend it.
TURBS
"Sabre owners united"
Old 06-03-2014, 10:46 AM   #23
I know who is (Missing the Point)! Any Member who has a (Rockwood/Lite any name) who lifts the (FRAME) at the (REAR area),will (BOW,Bend,Curve,or whatever you choose to call it) WAY Before the Tires come Off the Ground! Some Members cant even (open/close their Doors just by over using their (Stabilizer Elect.Jacks). Youroo!!
Old 06-03-2014, 10:51 AM   #24
SOLUTION: Make a 1/4" thick steel loop around the stab motor and LET 'ER DRAG!
Old 06-03-2014, 11:03 AM   #25
bud121156's Avatar
This is what I had on my recently traded KZ hybrid.
2007 Fleetwood Westlake .... 2011 KZ Sportsmen Hybrid
2014 Coachmen Freedom Express Bunkhouse
2000 Chevrolet Silverado 4X4 Ext Cab
bud121156 is offline   Reply With Quote
Old 06-03-2014, 11:08 AM   #26
We live on a very steep hill and I drag back corner on our 5th wheeler when backing into DW......I place some 2" x 8" or 10" planks (short pcs) at curb.....Two pieces on low side are enough to clear DW. J
Jim in Halifax is offline   Reply With Quote
Old 06-03-2014, 11:25 AM   #27
AquaMan's Avatar
Did OP mention anywhere whether this was a TT or 5er? I missed it if they did. If TT, may be possible to remove hitch bars and let the TV sag, in return lifting the rear of TT. This along with some boards under the wheels, may be enough.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 06-04-2014, 07:15 AM   #28
Aquaman,their unit is a (Travel Trailer) 8329SS Rockwood. Youroo!!
Old 06-04-2014, 07:50 AM   #29
I will have to try what Aquaman suggested and remove the hitch bars. I live on a country road so I don't mind blocking one lane. They can go around.
Old 06-04-2014, 08:26 AM   #30
2x12's are cheap and simple and dont stress the frame. Just remember you only need to lay the boards to cover the small area that you might drag. I use 2x12's all the time to load very low cars onto a tow truck, and even take care of clearence issues on trailers (though my 5th wheel has gobs of clearance.)
jbrostek is offline   Reply With Quote
trailer
