Old 06-11-2014, 07:30 AM   #31
Tried removing hitch bars and the front and back drug. On a trip now and when I get home I will make some straps like scoot suggested and let her drag.
psrujak is offline   Reply With Quote
Old 06-11-2014, 07:40 AM   #32
If you can't move the jacks forward a little, that's exactly what I'd do., install a 1/4" thick steel loop attached to the frame to protect the motor and let it drag momentarily.
Old 06-11-2014, 09:09 AM   #33
Fulltime family RVer
Out of curiosity, if it's just a little bit of dragging, why not put boards down to drive onto to give you an extra inch or two of lift?
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 06-29-2014, 07:18 PM   #34
Here is an update on the trailer dragging. After our trip to Williamsburg, I did what OldCoot suggested and moved the rear jacks forward. I drilled into the frame an raised the jacks about four inches. Before anyone says I voided my warranty by drilling, it was either that or tearing off the jacks.
I am just back from a three day trip and the trailer never drug leaving or pulling in.
Old 07-02-2014, 03:56 PM   #35
Glad it worked out for you. Hopefully the jacks weren't damaged prior to you moving them.
Old 07-02-2014, 10:02 PM   #36
They were fine this past weekend.
trailer
