Old 06-30-2018, 08:23 PM   #1
Trailer Tire Pressure Monitoring System-TPMS
Does anyone have a system which they like? I figure a TPMS is cheaper than the insurance deductible for the tire blowout damage.
mlawler506 is offline   Reply With Quote
Old 06-30-2018, 08:25 PM   #2
SeaDog's Avatar
I run the tst 507 and highly recommend it
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-30-2018, 08:39 PM   #3
Thank you for the tip. I will investigate.
Old 06-30-2018, 08:42 PM   #4
Enjoying Life
X2
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!” - Hunter S. Thompson, The Proud Highway: Saga of a Desperate Southern Gentleman, 1955-1967
TeachTexas is online now   Reply With Quote
Old 06-30-2018, 09:10 PM   #5
SailorSam20500's Avatar
X3
Al
Save the Earth. It’s the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is online now   Reply With Quote
Old 06-30-2018, 09:54 PM   #6
ColoradoRick's Avatar
We've used the EEZTire system for a few years, now, and highly recommend them. Even with an Max Crew Cab Tundra and 32 foot trailer it doesn't need a repeater.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 06-30-2018, 10:50 PM   #7
mblee21's Avatar
I had a zero deductible for my blowout coverage.
mblee21 is offline   Reply With Quote
Old 07-01-2018, 09:55 AM   #8
I also have the EEZTire system and am very pleased with it. The sensors work without a repeater on my F250 & 24’ Car Trailer combination. I need a repeater for the system to communicate reliably on my F250 & 35’ Windjammer TT combination.
I swap the wheel sensors back and forth all the time between trailers and have changed the sensor batteries once in the three years I’ve had the system. I remove the sensors from the wheels when not using either trailer so that the sensors go into the low power drain mode.
My sensors are the non-flow through kind. I inflate the tires 1 psi high figuring I lose a psi when mounting the sensors. The correlation between EEZ sensor readings, electronic pressure gauge and expensive analog gauge (for my race car) is perfect.
TJA1 is offline   Reply With Quote
Old 07-01-2018, 10:27 AM   #9
Flybob's Avatar
This will solve the financial portion of the issue, but will not salvage the ruined vacation due to the loss of the waste plumbing caused by driving with a shredded tire.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-01-2018, 10:39 AM   #10
With dozens upon dozens of systems out there, how do you really decide on what's best ?
TheWolfPaq82 is offline   Reply With Quote
pressure, tire, tpms, trailer
