Old 10-22-2011, 09:09 AM   #11
Sgt. Schultz's Avatar
Evergreen info can be found at Evergreen Recreational Vehicles - Manufacturer of Green Eco-Friendly Travel Trailers and Fifth Wheels a new company started in 2008.
You may want to check out some of the areas you want to frequent to see if they have sufficient numbers of sites that can handle 30' + trailers - in my area they are currently limited so prime times are very difficult to get.
As for brand you may want to check Surveyor Travel Trailers & Fifth Wheels Floorplans they are rolling out a 10th Anniversary Edition with nice feature included
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 10-22-2011, 09:24 AM   #12
Glenn5995's Avatar
Welcome to the forum!
With a good hitch set up, such as Equalizer or Reese Strait Line (aka dual cam), there would not be any problem towing a trailer in the size range you are considering as long as the weights (tongue and total) are within the ratings of your tow vehicle. Although it would tow well on the road, the longer the trailer, the more room you need to maneuver. This can be a problem if you anticipate primitive (aka "boondocking") camping or some of the national forest campgrounds where there may be tight turns and limited space. This probably will not be an issue for you as you believe you will be mostly in established campgrounds with full hookups. These types of campgrounds are well equipped to handle trailers this size and larger.
Be warned - as you are familiar with towing a fifth wheel, pull behinds will not tow as stable as a fifth wheel. They still tow very nicely, but by their nature, you will feel their input to the tow vehicle's steering/stability more than you will with a fifth wheel.
Good luck!
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
Old 10-22-2011, 09:27 AM   #13
TURBS's Avatar
I pulled a 34' tt with my 2500hd short bed with no issues on interstate
