Old 10-21-2011, 04:54 PM   #1
Travel Trailer Length
Hello, Newbie here with first rookie question. We are coming from a small class c and looking seriously at the longer (28-34) Rockwoods. Several of my friends are warning me about the difficulty traveling with such length.
Years ago we pulled a 32' 5th wheel. I would appreciate any comments on handling the big stuff. Thanks, Bill
rancherwillie is offline   Reply With Quote
Old 10-21-2011, 05:09 PM   #2
Remember, coming from a MH to a TT you will find tons more interior room in the TT for a given length. Personally I would not again consider pulling a TT longer than about 25 feet. Just too much sway unless you can find a really long wheel base TV to handle it. I am always reminded of the picture of the tail wagging the dog.
Old 10-21-2011, 05:46 PM   #3
bikendan's Avatar
a lot has to do with how you're going to use the trailer and what you'll be towing with.
if you want to "camp", instead of "RVing", a shorter trailer is a good idea since camping usually means in state/national parks that have smaller sites and you're taking shorter trips.
if you plan on RVing or full-timing, a larger trailer will be more suitable, since you'll primarily stay in RV parks/resorts and be living in them more. these places will have pull-thru sites and be longer for bigger rigs.
and having an adequate tow vehicle is a huge factor. if you've had experience with a 5th wheel, a bigger TT shouldn't be that hard for you to handle. but you won't have the high ceiling that the 5th wheels have, with a TT.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-21-2011, 05:54 PM   #4
We plan to travel less and shorter distances but stay much longer thus the need for more floor space. Our destination will be 99% full hookups in common rv parks. We are hoping to use our 06 F150 5.4 V8. Mountain roads and passes will be very few in our plans.
Old 10-21-2011, 05:58 PM   #5
stevengb's Avatar
I disagree with Donn. We went from a popup to out surveyor sp295 which has a total length including tongue of 33' and I have had NO problems pulling, backing, or swaying. I have a half ton chevy crew cab and EZ LIFT equalizer hitch with sway control and pulled it home last weekend in 15-25 mph wind gusts with no scary moments. Our trailer weighs 5100 lbs empty. Don't let length scare you from having enough room to be comfortable.
Steve and Michele Bassett
2014 Surveyor Select SV305
2005 Ford F250 Lariat SuperCab 6.0 TurboDiesel
stevengb is offline   Reply With Quote
Old 10-21-2011, 06:01 PM   #6
stevengb's Avatar
And we have stayed totally in state park and corp. of engineer campgrounds only one having full hookup.
Old 10-21-2011, 06:02 PM   #7
bikendan's Avatar
then i think a larger ultra-lite TT would be perfect for what you plan to do. be sure to get one with at least one slideout, really opens up the floorspace.
just as long as your Ford has the factory tow package and you stay within 80% of its tow capacity.
Old 10-21-2011, 08:02 PM   #8
softwarejoe's Avatar
I disagree with Don too. I Have a 2010 f150 5.4 6 speed supercab with 5.5 box and trailer package and I'm pulling a 35' 7500 lb trailer.
I use equalizers and 1 sway bar and she pulls just fine
Moose Jaw Saskatchewan
2012 Surveyor 305 B-309
2010 F-150 4x4 supercrew Lariat 5.4 3.55 ratio
Power moon roof and back window
TV GVW without me 1/4 tank 5870 lbs
Days camping 20011-4 2012-26 2013-29
softwarejoe is offline   Reply With Quote
Old 10-22-2011, 08:20 AM   #9
This is a timely post. We are about to purchase an Evergreen Everlite 35 ft TT. A big upgrade in length from our 2502s TT. We are a bit concerned about getting into some campsites with the longer TT and our driveway. Otherwise we are good to go with our TV, 2011 Tundra 5.7 with tow package.
toadswife is offline   Reply With Quote
Old 10-22-2011, 08:59 AM   #10
Evergreen is a new name to me. Are they part of another company?
Are they in the Rockwood quality/cost arena?
