Old 09-23-2012, 06:53 AM   #1
RalphieAdie's Avatar
Traveling with your TT or 5'er in Winter
When on the road during the winter, how do you keep your waterlines from freezing during the day? Or is the motion of the unit enough to keep the lines from freezing?
Ralph & Adrienne
2016 Flagstaff 8528CKWSA
2012 GMC Sierra 2500HD 6.0L
RalphieAdie is offline   Reply With Quote
Old 09-24-2012, 06:19 PM   #2
Paul & Sheri
pwb01's Avatar
I have 12 volt heaters for all 4 tanks. I assume I run the heaters while on the road but what about the water lines? Can you run the furnace while traveling? My tanks are in heated spaces so if you can run the furnace why the 12v tank heaters?
I'm back to the original question.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 10-09-2012, 08:57 AM   #3
Tanks fill cavity so no room for warm air to circulate. Heaters are underneath tanks. They are only about the size of a sheet of paper but heat rises to tank. Furnace would also have to be on to keep trailer above freezing.
jacknel is offline   Reply With Quote
