Old 12-16-2017, 08:59 PM   #1
ADK
Tried removing spare tire but lug nut galled.
I was going to move my spare tire over more toward the center and the lug nut was galled. This is a new trailer and spare was mounted on the back when it arrived so FR must have done it. The lug nut started spinning in the bracket so had to use a cutoff wheel in a high speed to cut the bolt to get it off. I sure am glad I found this out today instead of on the Hwy when I would really need it. I am going to tack weld the new bolts on and use anti-seize so it will be available when its really needed.
ID:	158476   Click image for larger version
ID:	158477   Click image for larger version
2017 F-150 XLT EcoBoost 3.5 Crew Cab 4x4
2018 Rockwood #8328BS
ADK is offline   Reply With Quote
Old 12-16-2017, 09:12 PM   #2
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Great you dodged what could have been a ton of grief on the road!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14
2001 Ford F-250 7.3
A Loving wife and Mason the always dirty dog!
Paulie1138 is offline   Reply With Quote
Old 12-17-2017, 12:57 AM   #3
Cyclemike's Avatar
Looks like it was mounted with big air wrench and either cross threaded or the thread were buggered up to start with.
Mike & Mary
2013 Rockwood Signature Ultra Lite
2011 Ford 250 Lariat Superduty
Cyclemike is offline   Reply With Quote
Old 12-17-2017, 02:41 AM   #4
Timely find, just like I discovered the two lug nuts on my spare are a different size than the ones on the ground!
jjmffca is offline   Reply With Quote
Old 12-17-2017, 04:37 AM   #5
DouglasReid's Avatar
Good Catch! I had something similar happen. Since Im not a welder I used a bolt to replace the carriage bolt the factory used. This way I can put a wrench on both ends. I also used some thread lube.
2012 Wildcat Sterling 32RL, Maxxis 8008s Load rating E, TST 507 TPMS w/ Flow-thru Sensors & Repeater
2008 Chevy Silverado 2500HD LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer
DouglasReid is offline   Reply With Quote
Old 12-23-2017, 05:25 PM   #6
Same thing happened to me, luckily I had a socket to fit.
Harvey9 is offline   Reply With Quote
Old 12-24-2017, 12:32 AM   #7
Grammar Pedant
67L48's Avatar
For being really unlucky (galled threads), you were extremely lucky (found it now instead of on the road). I'd be pissed off, but it's super awesome that you found it when you could actually fix it.
Good luck.
TV: 2005 F150, 5.4L, Tow Package, 4WD
Current RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 12-30-2017, 02:24 AM   #8
heiseygal's Avatar
Thanks for posting...we'll check ours Now! One year old newbies. Read the daily posts in forums...very enlightening! HAPPY NEW YEAR..SAFE TRAVELS!
heiseygal is offline   Reply With Quote
led, tire
