Old 04-30-2016, 10:55 PM   #1
Turning F150 Towing Rockwood 8289
Bought our first 5th wheel last fall. It was delivered and I picked it up and put into storage before the snow flew. I will be picking it up next weekend to bring home so we can get it loaded with our gear and get set for another year of camping.
I'm looking for feedback on the turning radius from other owners. I have a 2015 F150 w/6.5' box. I have a Curt hitch and wondering if I'll be able to turn at a 90 ' or close to it without changing the pivot pint to the pin box (with Sidewinder hitch).
Thanks in advance for any feedback.
Daross
2015 Ford F-150 Lariat
2016 Rockwood 8289WS 5th wheel
2013 Dutchman 278RLS TT
Darross is offline   Reply With Quote
Old 05-01-2016, 12:06 AM   #2
Iggy's Avatar
With a 6.5' box I don't think your present mount will be able to turn 90 degrees without hitting your truck cap.
Now if you had the sidewinder it will work in your case with a 6.5' bed.
Hopefully someone here has a short bed that can answer your question.
Here is a link to a place you can ask that question.
https://www.etrailer.com/Fifth-Wheel...e/RP61420.html
At the bottom of the page it has a formula and shows how to check.
It also has pictures. lol
Good luck
Old 05-01-2016, 06:07 AM   #3
Big Rig's Avatar
I have a 8265 that I used to pull with a 6.5 bed and always used the sidewinder option. Why wouldn't you use it if you already have it? Never had a problem with the key. The only reason I changed trucks is because towing it with a half ton felt unsafe.
Big Rig is offline   Reply With Quote
Old 05-01-2016, 06:28 AM   #4
nomad297's Avatar
You don't say. I wish more people were as smart as you.
Bruce
Old 05-01-2016, 07:05 AM   #5
B and B's Avatar
Same Trailer and had a 2013 F 150 with a 5.5 ft box. Could do 90 degrees with sidewinder. You will need it with a 6.5 ft box.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-01-2016, 11:26 AM   #6
I towed my 5th wheel with a 1/2 ton and never felt unsafe. It did just fine but what I didn't like was the fact that I had little to none spare cargo carrying capacity. My fiver weighed 7300 lbs dry which was well under the vehicle's tow rating. That darn pin weight will getcha every time on a 1/2 ton.
Skyliner is offline   Reply With Quote
Old 05-01-2016, 11:45 AM   #7
GreenImp's Avatar
Send a message via MSN to GreenImp
I tow an 8289ws with a 6.5' bed...no slider and the Revolution is locked. I can't say that I can do 90°, but I can maneuver the trailer anywhere I wish. Frankly, I find all the marketing hype about turning a 5th wheel 90° laughable. You don't see the TT crowd worried about turning 90°. And our 5th wheels are naturally more maneuverable anyway (pivot point further forward).
Remember...SB trucks w/5th wheels don't dent cabs....DRIVERS of SB trucks w/5th wheels dent cabs.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 05-01-2016, 04:10 PM   #8
HAMMDOWN's Avatar
I have a Toyota Tundra w/ 6.5' bed pull the 8289 w/ revolution hitch locked no problems
2014 Rockwood 8289
2013 Toyota Tundra
HAMMDOWN is offline   Reply With Quote
Old 05-05-2016, 02:24 AM   #9
RangeMaggotBob's Avatar
[QUOTE=HAMMDOWN;1181793]I have a Toyota Tundra w/ 6.5' bed pull the 8289 w/ revolution hitch locked no problems
You're a brave man HAMMDOWN.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 05-05-2016, 02:56 AM   #10
Witch Doctor's Avatar
Good luck
X 2 you will hit at 90 degrees without using the revolution, get the correct wedge for your hitch
Coachmen M/H
Concord
2018 / 300 DSC
f150, rockwood, towing
