Old 08-08-2012, 02:48 PM   #1
TV antenna ?
Hello all,
We've recently taken delivery of our new 2013 Rockwood 8280WS and so far it looks great... just can't wait to get it out and use it!!!
One question I have so far, I was up on the roof looking at the TV antenna and saw that when it is in the down position it rests on the 'transition' hump where the roof slopes to the back. What I mean is the head of the antenna is sitting about 6" (or more) above the roof so the little 'bumpers' are not touching the roof and all the weight of the antenna is resting on the 'hump' of the roof. I'm afraid it will rub there and wear a hole in the room membrane. I'm a bit surprised the trailer was built this way... any suggestions/ideas??
thanks in advance,
Gord
cachencouple is offline   Reply With Quote
Old 08-08-2012, 04:11 PM   #2
showtime0022's Avatar
Take a pic
showtime0022 is offline   Reply With Quote
Old 08-08-2012, 04:27 PM   #3
Good suggestion... I hope these are worth 1000 words
ID:	17711   Click image for larger version
Old 08-08-2012, 04:53 PM   #4
I would get some rubber bumpers and put them on where the shaft meets the roof..When I changed to THE JACK antenna that is what I had to doe because the old bumpers were on the original antenna head. The local hardware should have some bumbers,easy to install.
Tbonz is offline   Reply With Quote
Old 08-09-2012, 06:10 PM   #5
Thanks for the suggestion, Tbonz. I was thinking of something along the same lines. I think I might just get some lap sealant and put a little blob on the roof where the antenna hits. That way the movement of the antenna could ware on that instead of the roof membrane.
I guess I was hoping someone with the same model trailer could comment as to weather their unit's TV antenna was installed the same way or not.
It just seems like a really strange way to mount it.
thanks again.
Old 08-15-2012, 11:08 AM   #6
Or possibly a piece of eternabond .
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Old 08-15-2012, 11:51 AM   #7
from the looks of it looks to be mounted 180 degrees opposite where it needs to be.
skipper194242 is offline   Reply With Quote
Old 08-15-2012, 11:55 AM   #8
x 2
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 08-15-2012, 12:00 PM   #9
Herk7769's Avatar
Without rotating the entire base you may just need to pad the roof with Eternabond like I did.
Use 2 or even 3 layers at the contact point.
Name:	913th 3rd Annual Picnic and Camper photos 036.jpg
HAM CALLSIGN - KC3FFW
Old 08-15-2012, 12:01 PM   #10
MilCop4523's Avatar
Originally Posted by Tbonz View Post
I would get some rubber bumpers and put them on where the shaft meets the roofThe local hardware should have some bumbers,easy to install.
The glass shops are a better place to get them. Used for stone guards on your hood. JUST MAKE SURE YOU PLACE THEM ON THE ROOF and not the antenna itself or they will wear through the rubber roof liner itself.
The kid who put my stone guard on my car set them on the guard and with the wind it wore a hole through the paint and primer in about 3 months.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
antenna
