Old 07-17-2015, 09:55 PM   #1
TV antennae
We are on our inaugural trip in our new mini-lite and while the antennae is up, the TV says no signal. Any advice? Should the TV/audio system be on a special setting or channel? Otherwise, the trip is going AWESOME:-)
the-s-moores is offline   Reply With Quote
Old 07-17-2015, 10:21 PM   #2
Make sure the amplifier is on. There's a switch behind the TV where the antenna cable is attached. Should have an LED lit.
2011 Traverse LT, 3.6L, FWD
Old 07-18-2015, 10:14 AM   #3
Thank you! That would be the first step lol .. But still "no signal" :/
Old 07-18-2015, 10:23 AM   #4
Did you scan channels?
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-18-2015, 10:27 AM   #5
Mr. Dan's Avatar
Did you tell the TV to use the antenna as its input?
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 07-18-2015, 10:33 AM   #6
RSchleder's Avatar
Go into MENU, go to setup tv, be sure tv is set on antenna when using antenna, set to cable when using campground cable system. After being sure your on antenna (assuming your using it), do a channel scan. This may take a few minutes and don't interrupt the process. Once the scan bar reaches 100%, the tv will revert to a channel and you can navigate thru all the channels found during the scan. This process will only be successful with the amplifier light on and the antenna pointed in the general direction of the local stations. Good way to determine the direction to point your antenna is check out other rv's in the campground and emulate them! Good luck.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 07-18-2015, 12:53 PM   #7
I cannot thank you all enough! We now have 20 crystal clear channels!! :-)
Old 07-18-2015, 01:29 PM   #8
RSchleder's Avatar
Outstanding---enjoy!
30 years RV'ing
11 different RV's
Old 07-18-2015, 01:44 PM   #9
bikendan's Avatar
what was the solution, so others can be helped?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-18-2015, 02:53 PM   #10
We had not run the channel scan. Rookie mistake. I went to set up and followed the steps in the set up wizard. Thank you all again for your kindness.
antenna, antennae
