Old 07-06-2010, 08:37 AM   #1
TV Connection
We just went for our first trip in our new 21RS Roo and although I thought it would be easy to connect up our LCD TV I couldn't get it to work. On the TV shelf there are two coax connections and I figured one was for the Antenna and one for the DVD or something. I tried using both the Antenna and the DVD player and they didn't work. There is another plate near the door that has the amp along with the TV and AUX/SAT connectors on it. When I plugged the TV into that it worked. Can anyone tell me how to use the two coax connectors on the shelf. Is one only for outside cable hookup ? The literature that came with the DVD player and the trailer are absolutely no help.
NewEnglandCamping is offline   Reply With Quote
Old 07-06-2010, 08:45 AM   #2
Yes, one of the coax connections is for antenna & the other one is for Sat/Park Cable.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 07-06-2010, 09:20 AM   #3
Was there a little button to push beside the Ant connection that you tried @ 1st? If yes, you have to press it to turn the amplifier/booster(?) on.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 07-06-2010, 09:57 AM   #4
Connection
The plate near the door of the trailer does have the amp button with the two coax jacks. The two coax jacks that sit behind the TV shelf are not labeled and do not have a amp button. I tried pushing the booster to see if it effected the coax jacks behind the tv shelf but no luck.
rockwood
