Old 07-26-2015, 11:08 PM   #1
TV in Bedroom?
I'm looking at mounting a 24" TV in the bedroom of our 8280. Does anyone currently have atv already installed? If so, can you send, or post, pics of the bracket you used? Also, wondering what kind of mounting acres screws this would require?
Thx,
Guzzel
guzzel is offline   Reply With Quote
Old 07-27-2015, 05:35 AM   #2
I also have the 8280ws with a 24" in the bedroom. I used a tilt mount that I picked up at Walmart. I used lag screws with several washers on each. Did not want them going through the thin wall. I am sure you can get shorter lag screws but I used what I had. Will send pics shortly.
Backfire is offline   Reply With Quote
Old 07-27-2015, 05:41 AM   #3
Name:	ImageUploadedByForest River Forums1437993638.394249.jpg
ID:	84291Click image for larger version
Name:	ImageUploadedByForest River Forums1437993664.634280.jpg
Old 07-27-2015, 06:28 AM   #4
Thx for the reply. What size lags did you use? My worry, like yours, is punching thru the bathroom wall. They seem somewhat thin. Also, is your TV all the way against the side wall?
Old 07-27-2015, 07:18 AM   #5
Don't remember the size. You can tell if it will go through or not since you can see the thickness of the wall.
I left a 1/4" gap between the TV & the wall.
2016 Rockwood 8280WS
2014 F-150 5.0 Supercrew
Prescott, Michigan
Old 07-27-2015, 07:34 AM   #6
jeff64's Avatar
I put one in on a 27vrl. Outside the coach is a tv bracket with two keystone holes. In order to mount the tv outside( if I ever wanted to) I contacted FR customer service with the year, model # and S/N of the TT. The sent the exact bracket that did the job. I think it was $106.( kinda pricy, but it works ) I bought a 24" RCA led, 1080p with built in DVD at Sears for about $200. I had to spot respot 2 of the attaching holes to the TV and come up with 4-4 mm screws, Knowing the walls arent that thick I used 6 #14 x 1" sheet metal screws. I could tell when I drilled through the outer panel, that there was a tougher material underneath. Had a piece of masking tape on the drill so I didn't drill too far. Measure 2x drill once!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 08-03-2015, 10:49 AM   #7
leefl's Avatar
Let us know how you get on.
I'm in the exact same situation. Wanting to install a TV in the bedroom of our new 8281WS.
We don't have the extra door into the bathroom, and our TV mount point is right behind the shower
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 08-09-2015, 06:44 PM   #8
camping baba's Avatar
We had our dealer install a TV mount as part of our deal that locks for travel and is able to be pulled out and turned for viewing . Before they installed it there was a sticker on the wall telling where to put the blocking was in the wall .
2013 Silverado extended cab 4x4 1500 Series
camping baba is offline   Reply With Quote
Old 08-11-2015, 10:31 PM   #9
leefl's Avatar
I ordered the MorRyde TV1025H mount from Amazon, for a 22" TV/DVD Combo I already had (from using in our old PUP)
Going to mount it where the sticker is, just hoping the included screws aren't too long for the wall.
Old 08-12-2015, 07:37 AM   #10
Fivealive's Avatar
I used a pull out swivel mount and used webbing and buckles attached to the wall to secure it for transport. We use bubble wrap under the straps to prevent chaffing. This setup has worked well for 3 years.
Fivealive is offline   Reply With Quote
bed, roo
