Old 07-23-2013, 03:31 PM   #11
My friends have a Toshiba. I agree that all TV's are not equal. Yes I turned on the booster. Looking @ a 32" sony or Samsung. I don't watch a lot of tv but my wife does so I need to keep her happy. Would be sweet to watch the red wings in the playoffs again this fall tho.....Maybe dish is the answer. Thanks for all the replys.
bgarbo is offline   Reply With Quote
Old 07-23-2013, 03:36 PM   #12
tv reception
Originally Posted by Wiscampsin View Post
What brand of tv do your friends have? The reason I ask is not all tv receiver sections are created equal.
Nice Trailer guys.
Old 07-23-2013, 04:15 PM   #13
Fivealive's Avatar
You may have a bad connection in the coax. Even factory cables can be bad. You should have the cables checked out for continuity . For all others I highly recommend bypassing any splitters you have to unused connectors. The splitters really drag down the signal. If you use the bedroom connector you may need to use a one to two splitter and ditch the three way that feeds the outside connection. Buy good splitters, it makes a difference. Use the booster. You can try this if you DYI: http://www.amazon.com/Steren-Coax-Ca.../dp/B000GDDPRG
Fivealive is offline   Reply With Quote
